ikea benno help
Old 21-12-2006, 2:29 PM   #1
3,748, Level: 14
Points: 3,748, Level: 14 Points: 3,748, Level: 14 Points: 3,748, Level: 14
Thanks: Gave 51, Got 62
ikea benno help
as thread title suggests, i need help with the internal dimensions of this! its the one with doors btw.
just that my amp is a complete monster, 51cm deep and 23kgs too! would this fit on the bottom shelf???
i emailed ikea but they couldt help me with enquiry!
Old 21-12-2006, 3:04 PM   #2
jonny round boy's Avatar
8,448, Level: 21
Points: 8,448, Level: 21 Points: 8,448, Level: 21 Points: 8,448, Level: 21
Thanks: Gave 0, Got 13
Re: ikea benno help
Which Benno TV bench is it? This one, or this one?
Edit - sorry, just noticed 'it's the one with the doors on'....
Old 21-12-2006, 3:05 PM   #3
3,748, Level: 14
Re: ikea benno help
the first link jonny!
Old 21-12-2006, 3:07 PM   #4
8,448, Level: 21
Re: ikea benno help
Well that one is 600mm deep, so, assume 20mm max for the doors, and 5mm for the back panel, would give an internal depth of around 575mm. So your amp would probably fit, depending on how much space you needed for the cables behind...
onefunkypenguin (21-12-2006)
Old 21-12-2006, 3:51 PM   #5
3,748, Level: 14
Re: ikea benno help
think im going to leave the back panel off for circulation so not really a problem me thinks!
you think it should hold 23kg on the bottom shelf? my tv weighs 32kg and rest of equip isnt heavy so its way under the max 100kg total weight!
Old 21-12-2006, 8:47 PM   #6
8,448, Level: 21
Re: ikea benno help
Yeah, no problem.
