'Stand Suitable for 32" LCD TV" - Will a 37" LCD TV be alright on this?
Old 12-12-2006, 7:34 PM   #1
15,815, Level: 30
Points: 15,815, Level: 30 Points: 15,815, Level: 30 Points: 15,815, Level: 30
Thanks: Gave 37, Got 216
http://www.johnlewis.com/Shopping/Pr...7&source=14798
Will a 37" LCD TV be alright on this stand, despite it saying suitable to 32" LCD TV's.
Help appreciated. Thanks
Old 13-12-2006, 3:39 PM   #2
15,815, Level: 30
Re: 'Stand Suitable for 32" LCD TV" - Will a 37" LCD TV be alright on this?
anyone?
Old 13-12-2006, 3:46 PM   #3
sk8 sk8 is offline
sk8's Avatar
6,399, Level: 19
Points: 6,399, Level: 19 Points: 6,399, Level: 19 Points: 6,399, Level: 19
Thanks: Gave 14, Got 21
as its specifically designed for upto 32" i would be dubious of its ability to support a 37"
Old 13-12-2006, 7:35 PM   #4
jonny round boy's Avatar
8,448, Level: 21
Points: 8,448, Level: 21 Points: 8,448, Level: 21 Points: 8,448, Level: 21
Thanks: Gave 0, Got 13
Look at the weight rating - my bracket said 'up to 30"', but weight-wise it could take quite a bit more than my 32" weighed, so I figured it would be fine (it hasn't fallen down yet ).
Old 15-12-2006, 2:35 PM   #5
15,815, Level: 30
I can't find a wright rating for it, although similar ones seem to be up to 100kg. I've seen a 37" LCD on it in store, but wasn't sure what it would be like in the long run.
