Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
John Lewis Maharani Corner TV Unit
John Lewis Stowe TV Unit
John Lewis Matilda Bar Chair, Black
The Furniture Factory Worcester TV En...
Ellis Entertainment Unit, Light
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
 More...Prices updated November 22nd at 7:30pm and include delivery.
Old 10-12-2006, 11:49 PM   #1 (permalink)
Thanks: Gave 1, Got 5
Unhappy Shelf heights for Samsung system HT-XQ100
I need to find a suitable stand to put a 32" Sammy LCD plus HT-XQ100 Home Cinema system http://www.beyondtelevision.co.uk/pr.../xq100_lrg.jpgon.
Before I buy the system I need to know how high the front loading DVD door extends upwards so I can work out much the gap in the shelves needs to be for it to function properly. It may not even fit on a stand so I will be back to square one!!
Anyone out there know the answer??
confused dotcom is offline   Reply With Quote
Old 20-12-2006, 11:33 PM   #2 (permalink)
Unhappy Aaaargh!! Anybody got any ideas???
OK, so I got the system and have now discovered that the height of the DVD/AV unit is 35 cm when a disc is ejected upwards! This is way too much for the majority of the AV stands/cabinets.
I am trying to find something at least 100cm wide so that I can stand my 32" LCD on it with the front speakers beside it. The centre speaker is low enough to place in front of the TV without any viewing disruption so as long as the stand is deep enough .
Underneath I need to have the DVD unit as described above (see picture) and somewhere a Sky + box. Most of the usual stands like Alphason etc are two tier shelves so not suitable as the shelf gap is too small Does anyone know of a stand/cabinet that will fit the above?? Ideally it needs to be smoked/dark glass and chrome or metallic (not wood) as all of the other components are piano black. However, if I need to compromise then c'est la vie!
Old 21-12-2006, 12:58 PM   #3 (permalink)
Re: Shelf heights for Samsung system HT-XQ100
Ok, I guess it is a busy time of year and either
  • People are busy out shopping or down the pub
  • Nobody has come across this problem before!
Anyhow, after exhaustive searching I have worked out that I need a cantilever stand so that the LCD sits higher up, so that has narrowed things a bit! The Alphason models seem OK but I can't seem to find a black/dark glass one. I should also mention that I have a budget of around £150 max. If anyone is browsing this post and has a brainwave I would love to know.
Merry Christmas
Old 25-12-2006, 10:01 PM   #4 (permalink)
khackett21
Posts: n/a
Having the same problem as you. I have the 32" samsung LCD tv that goes with this system, and have just 100cm width to fit my stand in (otherwise a door will hit it!). I'm thinking of wall mounting the TV and speakers and just getting a nice stand/coffe type table to put the DVD unit and subwoofer on. Do you know how to connect the system up so you can have sound with the tv ? At the moment I can only get the speakers on when DVDs are playing!
Old 01-01-2007, 11:52 AM   #5 (permalink)
Thanks: Gave 125, Got 18
Unhappy Re: Shelf heights for Samsung system HT-XQ100
I hadn't really thought about getting the samsung ht-xq100 until after I bought a samsung 32" lcd and a cheapo stand from argos - unfortunately the height between each shelf isn't enough to accomodate the system. I'm considering taking out the bottom shelf to fit the system in.
MarkusThatch is offline   Reply With Quote
Old 01-01-2007, 2:22 PM   #6 (permalink)
If you are connected up to your TV with a HDMI lead then all you need to do is press the 'HDMI Audio' select button at the bottom of the remote or alternatively use the phono plugs to connect to the TV and run it through the AUX channel on the DVD. You can still get Pro Logic sound through the speakers if you turn the TV sound down.
Hope this helps.
Old 04-01-2007, 2:51 PM   #7 (permalink)
Can you use hdmi and optical with this system?
Old 06-01-2007, 1:24 PM   #8 (permalink)
You certainly can. HDMI will take care of your sound and vision when playing DVDs but the optical can be used when viewing TV, Xbox etc
heights, htxq100, samsung, shelf, system
