Glass Door Hinges?
Old 05-12-2006, 5:58 PM   #1
2,885, Level: 12
Points: 2,885, Level: 12 Points: 2,885, Level: 12 Points: 2,885, Level: 12
Thanks: Gave 13, Got 5
Glass Door Hinges?
Does anyone know where you can buy hinges for glass doors?
I am about to make a cabinet for my AV units and want to put glass doors/or glass flap on the front, but I can't find any place that sells hinges that fit on glass.
Old 05-12-2006, 6:06 PM   #2
lostprophet's Avatar
4,313, Level: 15
Points: 4,313, Level: 15 Points: 4,313, Level: 15 Points: 4,313, Level: 15
Thanks: Gave 4, Got 10
Re: Glass Door Hinges?
You could try this type where the glass just slots in top and bottom and pivots in a hole, see here
Old 05-12-2006, 6:45 PM   #3
2,885, Level: 12
Brilliant!!!!!!
That's just what I am looking for.
Many, many thanks.
