could someone cast their eye over this...
Old 05-12-2006, 9:45 AM   #1
4,065, Level: 15
Points: 4,065, Level: 15 Points: 4,065, Level: 15 Points: 4,065, Level: 15
Thanks: Gave 7, Got 0
hi ppl,
in the hunt for a black glass lcd stand for a 32" sammy. its gotta fit in an alcove of 104cm, along with a subwoofer which is approx 19cm wide. dont know whether to get a 80cm stand and stand sub next to it, or get a 100cm stand and lay sub on shelf?
ive spotted this one:
http://www.goshopdirect.co.uk/showpr...=SU-UK23080BLK
what to ppl think? is it cheap tat, or is it ok? it doesnt mention it has cable tidy, but it looks to me like it has?
got a budget of upto £120ish.
any suggestions would be much appreciated....
Old 05-12-2006, 9:58 AM   #2
lunker's Avatar
5,869, Level: 18
Points: 5,869, Level: 18 Points: 5,869, Level: 18 Points: 5,869, Level: 18
Thanks: Gave 12, Got 10
Re: could someone cast their eye over this...
I wouldn't put the sub on a shelf as they really need to be on a solid floor.
The shelves are only 400mm deep and most AV kit is deeper than that without cabling.
I'd measure all the equipment you are looking to put on the shelves. Remember you need to plug your Scart/HDMI/Coax/etc in as well.
