Need a rack to fit specs!!
Old 25-09-2006, 8:35 AM   #1
6,499, Level: 19
Points: 6,499, Level: 19 Points: 6,499, Level: 19 Points: 6,499, Level: 19
Thanks: Gave 4, Got 0
I need a very big rack with 5 shelves. The widths between each shelf should be:-
1 x 250mm, 1 x 170mm, 1x 180mm, 1 x 150mm or less
Can someone recommend one that will fit this size?
Old 25-09-2006, 9:52 AM   #2
Dankeech's Avatar
13,205, Level: 27
Points: 13,205, Level: 27 Points: 13,205, Level: 27 Points: 13,205, Level: 27
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 287, Got 322
Re: Need a rack to fit specs!!
1 x 250, 2 x 170, 1x 180
Hi, I'd like to help, but not sure what you mean by your measurements. Please clarify.
Thanks.
Dan.
Old 25-09-2006, 3:24 PM   #3
6,499, Level: 19
I hope you can help me. Thanks!
Old 25-09-2006, 4:14 PM   #4
Dankeech's Avatar
13,205, Level: 27
Activity: 0.7%
Ahh. I see you've edited your original post.....
Do you need hifi width (about 60cm) or do you need AV width (about 110-120cm)?
What are you looking for too - Metal & Glass (probably quite easy to find one), or wooden or something else?
Dan.
Old 25-09-2006, 6:13 PM   #5
6,499, Level: 19
I have a massive 5 channel power amp, a big processor, a large centre speaker, a dvd player and lastly a DLP tv to put on top. Not too bothered about whats its made from. it just needs to be good!
But the stand/rack needs to go upwards (so i can stack the components on top of each other) not sideways if you know what I mean.
Yes I think Hifi Width
Old 25-09-2006, 7:40 PM   #6
6,499, Level: 19
No not side by side but on top of each other.
Old 25-09-2006, 7:58 PM   #7
Knightshade's Avatar
11,666, Level: 25
Points: 11,666, Level: 25 Points: 11,666, Level: 25 Points: 11,666, Level: 25
Thanks: Gave 13, Got 51
I know they custom build so they may be able to help you.
Old 25-09-2006, 8:33 PM   #8
6,499, Level: 19
Thanks Knightshade.
Custom build usallly means very expensive to me. My budget is only £200.
Old 26-09-2006, 8:09 AM   #9
11,666, Level: 25
OK, I doubt they'd build it for that....
Try http://www.apollohifi.co.uk/ they do modular stands for reasonable prices. I think about £60-£80 per shelf. They quite often come up on ebay so if you can find virtually what your looking for then just buy the taller supports.
Old 26-09-2006, 1:46 PM   #10
6,499, Level: 19
I saw a Henleys MR5
Old 27-09-2006, 10:16 AM   #11
6,499, Level: 19
Anyone?
Old 03-10-2006, 11:45 AM   #12
Jual
Posts: n/a
Have a look at http://www.supportsav.co.uk/sd005.html
Old 03-10-2006, 11:46 AM   #13
Jual
Posts: n/a
Old 03-10-2006, 3:41 PM   #14
michaelk
Posts: n/a
have a look at
http://www.atacama-audio.co.uk/equipmentracks.htm
you order the shelves seperatly so can specify the sizes you want
I've gone for the Europa Reference 8 and am very very happy with it (see 40X too close to the fire ?)
Michael
Old 03-10-2006, 8:30 PM   #15
inzaman's Avatar
22,356, Level: 36
Points: 22,356, Level: 36 Points: 22,356, Level: 36 Points: 22,356, Level: 36
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 126, Got 543
Hi Jual welcome to the forums, all of your posts so far have linked to that website; you are not affiliated with them by any chance are you?
