All this talk of dual Oppli gave me an idea for a dual LACK TV stand. Unfortunately the Oppli center shelf is not wide enough for my center speaker (B&W LCR60 S3), and the wood color does not match any of my other furniture. The Ikea LACK shelving unit on its side, with some modification to the shelf positions could work nicely.
I am referring to this:
http://www.ikea.com/webapp/wcs/store...roductId=11317
I want to get two, put them on their side and on top of each other. Then I would reposition the shelves like so (involves drilling some holes):
- On the top unit, I would remove the middle shelf, then move the other two shelves closer together to make a middle compartment for my center speaker.
- On the bottom unit I would keep the middle shelf in place, but I would widen the two middle compartments to fit my HTPC and AV receiver.
- There would be plenty of room on each side of the TV to place my front speakers (B&W DM600 S3, bookshelf size)
I plan to put a Sharp 46" LCD on top of it, which weighs about 79 lbs. (36kg) according to specs. So the 110lb/50kg "max load" stated on the Ikea page is a bit of a concern -- but I don't know if that is referring to the load on each shelf when the unit is upright, or load on the side when it is horizontal.
I also can't decide if I would put castors on the bottom unit, or just let it rest flat on the ground (carpet). I am thinking flat on the ground would be better for weight distribution, but castors would make it easier to swing out for accessing the rear.
I photoshopped the basic idea, see the attached image.
If it works, it would be perfect for my needs, and pretty inexpensive. What do you Ikea hackers think? Is it possible? Will it be sturdy enough, especially after the modifications?
