Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
Caxton royale wide tv entertainment unit
Metropole Ocean TV entertainment unit
low entertainment unit
The Furniture Factory Worcester TV En...
Caxton Coniston wide TV entertainment...
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Mercury TV entertainment unit
 More...Prices updated November 24th at 2:30am and include delivery.
Help!!! Center speaker stand Movieman AV Stands, Cabinets, Seating and Furniture 6 18-12-2008 10:10 AM
Help!! Which stand will fit my Mordaunt shor ms905 center speaker Incksy AV Stands, Cabinets, Seating and Furniture 0 15-07-2006 7:21 AM
Looking for stand,cabinet? brian.w AV Stands, Cabinets, Seating and Furniture 0 22-11-2005 8:11 AM
Stand for Canton CD1 center speaker jcaiado Speakers 2 23-03-2005 4:04 PM
Bi-amping my fronts with the RX-V650 & Center speaker stand Q's. BloodyL AV Amplifiers and Receivers 5 20-08-2004 6:36 AM
Old 13-09-2006, 4:25 PM   #1 (permalink)
pmc
pmc's Avatar
Thanks: Gave 44, Got 87
Center Speaker Stand - no not a cabinet, just a stand
After much searching on this forum and much much Googling I still can't find a dedicated center speaker stand.
The issue is that I am a projector user. So there is no TV to put it on or AV cabinet to put it in. All the AV equipment is behind me. All I have is a lovely big white wall with left and right speakers stood at the sides on some nice stands and center sitting in the middle on a box. Aaarrgghh!. I suppose I could just buy a table and put it on top but it would look so much better to have a proper stand.
It needs to be about 18 inches tall, about 18 inches wide and 6 inches deep, i.e shaped like a center speaker. That sort of width is bigger than most standard stands. And no, I can't use brackets as I can't attach anything to the wall.
I have found some stands that it would fit on but they all come in pairs as they are designed for large stereo speakers. It seems a bit pointless buying two and throwing one away. If anyone is having the same problem and wants to split a pair with me let me know though.
So, any suggestions?
pmc is offline   Reply With Quote
Old 13-09-2006, 8:08 PM   #2 (permalink)
inzaman's Avatar
Thanks: Gave 91, Got 365
Re: Center Speaker Stand - no not a cabinet, just a stand
What speakers do you have?
Visit my Home Cinema here
inzaman is offline   Reply With Quote
Old 14-09-2006, 12:20 AM   #3 (permalink)
KTM
B&W make a wide centre channel speaker stand for their 800 range of speakers which may be of use depending on the size of your speaker.
The dimensions (from their Website) are.
Height :295mm
Width: 521mm
Depth: 312mm
As the speaker sits quite low, it can be angled upwards towards your listening position and get a choice of black or silver finishes.
I've been considering one for my Nautilus HTM1 but the bad news is they cost about £300. This may not be so bad as the probably only sell in limited numbers. My local dealer had to look up his catalogue to confirm they actually made one as I was the first person to ask about them.
Here’s a link to the stand…
http://www.bwspeakers.com/index.cfm/...%20HTM%20STAND
KTM is offline   Reply With Quote
Old 14-09-2006, 10:04 AM   #4 (permalink)
pmc
pmc's Avatar
Thanks for the replies guys. It's a Mission M3C2.
The B&W stand looks perfect but £300 is way over budget. I'm looking to spend £100 max.
Old 14-09-2006, 10:43 AM   #5 (permalink)
inzaman's Avatar
What about one of these you can only buy them in pairs (i think) but a short one with some foam angling the speaker upwards slightly could do the job?
I did think about one of these for my HTM1 centre but in the end went for the B&W stand which is perfect for a centre speaker imx.
cabinet, center, speaker, stand
