Low sideboard AV unit - Help
Old 12-09-2006, 8:37 AM   #1
2,985, Level: 12
Points: 2,985, Level: 12 Points: 2,985, Level: 12 Points: 2,985, Level: 12
Thanks: Gave 6, Got 4
I'm after an AV unit that looks like a low sideboard. I want it in Walnut. Essentially i want it to look like an item of furniture and not a AV rack.
Any ideas?
Old 12-09-2006, 10:40 AM   #2
5,966, Level: 18
Points: 5,966, Level: 18 Points: 5,966, Level: 18 Points: 5,966, Level: 18
Thanks: Gave 10, Got 27
Re: Low sideboard AV unit - Help
http://dwell.co.uk/product.php?prod=102268
Any good?
Old 12-09-2006, 12:22 PM   #3
2,985, Level: 12
No, I'm looking for something a bit bigger than that. I'm wanting doors on it and 3 shelves in each door section.
Old 13-09-2006, 8:04 AM   #4
5,815, Level: 18
Points: 5,815, Level: 18 Points: 5,815, Level: 18 Points: 5,815, Level: 18
Thanks: Gave 162, Got 98
I've got some Corndell furniture on order at the moment, it's pricey but they have a large range and in a variety of solid woods.
I've gone for the Nimbus oak sideboard
..and will be installing 2 12cm PC fans to manage the heat. I'll be using the Radio frequency feature on the Harmony 895 remote to control everything with the doos closed
Old 14-09-2006, 8:47 PM   #5
SadR0bot's Avatar
3,762, Level: 14
Points: 3,762, Level: 14 Points: 3,762, Level: 14 Points: 3,762, Level: 14
Thanks: Gave 19, Got 26
Just added a thread about a Next unit I found, have a look at that., doesnt have three shelves though mate.
