Speaker Brackets
Old 10-09-2006, 7:07 PM   #1
2,065, Level: 10
Points: 2,065, Level: 10 Points: 2,065, Level: 10 Points: 2,065, Level: 10
Speaker Brackets
Hi i need to buy some speaker brackets.
I have bought some from richer sounds as they didnt seem to make the speaker sit off the wall very much however they are made of plastic and dont seem to be very strong the speakers were wobbling about a lot so for the moment i have them back as they were (in the way).
I want the bracket to be as discreet as possible
also cheap
The speakers are currently mounted to the wall vie a screw in the wall and that sits in a slot in the back of the speaker.
Old 13-09-2006, 11:44 AM   #2
AMc AMc is offline
8,476, Level: 22
Points: 8,476, Level: 22 Points: 8,476, Level: 22 Points: 8,476, Level: 22
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 37, Got 72
Re: Speaker Brackets
You need to tell us a bit more about the speakers - size, weight, location etc.
I use some reasonably heavy duty brackets from Argos to hold a Mission 700 and a Projector.
But the Mission is a mighty speaker about 35x25x30 - if you're mounting little surrounds it would be overkill.
Old 13-09-2006, 10:13 PM   #3
2,065, Level: 10
these are the speakers
http://www.argos.co.uk/static/Produc...er/5123229.htm
Old 15-09-2006, 1:55 PM   #4
AMc AMc is offline
8,476, Level: 22
Activity: 3.8%
These are exactly what I'm using
http://cpc.farnell.com/jsp/endecaSea...sp?SKU=ST00168
If you search for "wall speaker brackets" at that site you'll come up with a number of options many muh cheaper. Add VAT and postage to the prices though. They ship by courier and my stuff always turns up next working day.
