Looking for a cheap simple wall bracket for 42" LCD
Old 03-09-2006, 10:24 PM   #1
keez
Posts: n/a
No tilt, swivel....nothing. Just a bracket to mount a 42"LCD as close to the wall as possible. Surely you can get these for about £10 - £20....no?
Have looked on ebay, but nothing (for less then £30 anyway).
Old 03-09-2006, 10:35 PM   #2
17,802, Level: 32
Points: 17,802, Level: 32 Points: 17,802, Level: 32 Points: 17,802, Level: 32
Thanks: Gave 232, Got 568
Re: Looking for a cheap simple wall bracket for 42" LCD
i used the one from the power buy section..
http://www.avforums.com/forums/showthread.php?t=270154
though its around £49 all in..
try cpc.co.uk ?
prob is bigger the tv. heavy the bracket has to hold.... dearer the bracket is..
