Hans Solo DVD Case
Old 02-09-2006, 11:46 AM   #1
Thanks: Gave 2, Got 5
Hans Solo DVD Case
I've had some positive response to my DVD case I built, so I thought I'd add a new thread so everyone can have a look and see what you think...
It's full sized, and with the door closed, does look like a block of carbonite....
Old 02-09-2006, 12:32 PM   #2
Thanks: Gave 5, Got 45
Re: Hans Solo DVD Case
I Want One!!!!! Where did you get this from?
Old 02-09-2006, 1:14 PM   #3
Bacus's Avatar
7,443, Level: 20
Points: 7,443, Level: 20 Points: 7,443, Level: 20 Points: 7,443, Level: 20
Thanks: Gave 486, Got 342
This looks fantastic !!
How did you manage to make this ?
Old 02-09-2006, 1:36 PM   #4
The case itself I made from MDF, the door is a large sheet of MDF which has the solo screwed to it.
The solo was bought for about £350 and is made from pressed aluminium, so total cost was around £400 or so...
A bit of filler to blend it in, and a lot of time, and there we have it....
Old 02-09-2006, 3:52 PM   #5
hornz's Avatar
2,414, Level: 11
Points: 2,414, Level: 11 Points: 2,414, Level: 11 Points: 2,414, Level: 11
Thanks: Gave 10, Got 15
Thats amazing. But when you head in there for a movie do you subconciously reach for Return Of The Jedi? :P
