Wall mount TV stand
Old 01-09-2006, 4:37 PM   #1
4,195, Level: 15
Points: 4,195, Level: 15 Points: 4,195, Level: 15 Points: 4,195, Level: 15
Thanks: Gave 1, Got 7
Wall mount TV stand
I have been thinking about wall mounting a tv stand like this one but without the feet
http://www.ikea.com/webapp/wcs/store...umber=00105342
The idea is to get a floating look and it would hold my amp, dvd player and centre speaker. My LCD tv would be wall mounted aswell just above this so it wouldnt need to take the weight of it.
So i was wondering if anyone has seen or has a table or stand like this which is designed to be wall mounted?
Old 06-06-2007, 9:39 PM   #2
DOHCme
Posts: n/a
Re: Wall mount TV stand
Not a bad idea, anyone done this?
Old 17-06-2007, 9:04 PM   #3
Thanks: Gave 7, Got 0
Yeah has anyone done this?
I would love to be able to do this as it would look very very nice.
Old 21-06-2007, 11:55 PM   #4
4,195, Level: 15
Wow didnt think the first reply would be 9 month later lol, forgot i posted this thread.
Well i never did this idea in the end but did look into it, was gona use some metal shelf brackets to suport it under the top of the unit.
