27-08-2006, 6:15 PM
#1 (permalink)
Thanks: Gave 115, Got 5
Alphason AMBRI ABR1/100-B Plasma LCD Stand
This is daft question i have bought this unit recently, after looking for a closed unit I have not assembled it yet.
My question is this I have an amplifier that is 463mm Deep and I see that the internal measurements for the unit is 455mm deep is this acurate and will i be able to put my Amp in a close the door
I hope sombody who has the unit and built it can advise
CinemaGary
"It might not look much, but it's got it where it counts"
28-08-2006, 8:42 AM
#2 (permalink)
Thanks: Gave 28, Got 17
Re: Alphason AMBRI ABR1/100-B Plasma LCD Stand
Just set up my AMBRI unit up. Looks the business, however......the dimensions measured on the website of the depth being 468mm is from the outside to outside only. I've just measured the depth of the shelf for you and you get 440mm of space to fit your equipment in.
Although you get four holes in the backing board to route your cables through, I had to cut two extra holes for the power cord and for the video connections of my Denon receiver else the door didn't close. So I doubt you'll get your amp in unless you're ready to do a bit of DIY to it.
HTH
T
28-08-2006, 12:34 PM
#3 (permalink)
Thanks: Gave 1, Got 5
I am looking at this canbinet as well. I do not seem to be able to find anything else in this price range. Would it fit the following kit? or are there any suitable alternatives, which are reasonably priced?
Pioneer VSXD 1014 AV receiver 42 cm wide, 45 cm deep, 18 centimeters high
Philips DVD player 44 cm wide, 34 cm deep and 8 cm high
SKY HD box 40 cm wide, 30 cm deep and 8 cm high.
ALternatively, would the smaller version take all this kit as well??
Ener1
31-08-2006, 7:31 AM
#4 (permalink)
Thanks: Gave 1, Got 1
I bought one of these only to find my Yamaha 757SE was too long when speaker cables with banana plugs were attached. I ended up leaving the back panel off when assembling - structurally the stand is fine, you can just see slightly more of the wall behind it than otherwise.
cheers
Jon
08-09-2006, 7:06 AM
#5 (permalink)
Thanks: Gave 66, Got 177
Originally Posted by tazman007
HTH
T
..................so, my Denon 1906 amp would fit in this unit.................as long as I make a few more holes for the component leads?
The amp gets pretty hot. Is yours ok in there?
Do IR remotes work ok through the glass?
(Best price I have found is at Empire Direct - £164.98 delivered)
PanTH42 PHD8(Component)<< SkyHD 1TB >>(HDMI)SonyKDL20S Amp.DenonAVR1906/ MonitorBronze & KefEggs/ DVD.Sony DVPNS76H/ FVR.SonyVTX-D800U(JST RGB-Component)/ ProjectDebut3Turntable/ Marantz CD6002/ Harmony785/ Nikon D40 flickr
10-09-2006, 2:37 PM
#6 (permalink)
Yep, my amp still OK and no probs with remotes through the glass. Got mine from empire too at the same price!
Sony KDL-40V2000, Denon AVR-2807 Arcam AVR350, Quad L-ite speaker system with Quad 11L2 fronts, SkyHD, PS3 Sony BDP-S550, Mini i-pod docked with Denon ASD-1R - made redundant by the Logitech Squeezebox Duet, Nintendo Wii, Harmony ONE remote control. Upgrade bug has bitten
12-09-2006, 4:49 PM
#7 (permalink)
Pleased I got in when I did.................£199.99 now at Empire !
