15-08-2006, 12:38 PM
#1 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | How do you lot *cope* with centre speakers ?
I used to have my centre speaker on top of my tv (when i had a CRT) I now want it under my TFT
i have a bit of AV equipment but not a massive amount.
My idea was to buy some kind of shelf that the tv can sit on and the centre speaker sit under however my thread got very little response so i am assuming that kind of thing does not exist.
I have
hyundai A321 tv
Kenwood amp
Kenwood 200 cd changer
shuttle (small pc)
ps2
video player
ps1
Missions M7c2 centre speaker
I like the unit i currently have it suits my needs very well.
Have taken a picture which i will upload asap.
What do you guys do with your centre speakers ? Click picture for bigger image
15-08-2006, 1:03 PM
#2 (permalink)
| | Member
Thanks: Gave 2, Got 14 | Centre speaker
A lot of people use the Oppli stand from Ikea, which is similar to your existing stand and costs £56 (has it's own thread). I bought one and changed my centre speaker for an Eltax for only £9.95 from Richer Sounds, it fits perfectly and sounds very good. I have saved the existing centre for when I convert to 6.1 or 7.1 as a centre rear speaker.
15-08-2006, 3:57 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 5, Got 53 |
I bought a whole new wall unit to fit my centre under the TV and have the TV at the right height. Loads of units weren't quite right.
If you want a shelf to go on the existing unit why not make one from some MDF and four furniture legs. Shouldn't cost much to do.
Mat
19-08-2006, 6:04 PM
#4 (permalink)
| | Member
Thanks: Gave 4, Got 30 | Quote: |
Originally Posted by No3ntry I used to have my centre speaker on top of my tv (when i had a CRT) I now want it under my TFT
I have
hyundai A321 tv
Kenwood amp
shuttle (small pc)
ps2
video player
ps1
| Here is one solution.
20-08-2006, 8:31 AM
#5 (permalink)
| | Moderator
Thanks: Gave 91, Got 365 |
That looks a fairly smart solution
__________________ Visit my Home Cinema here |
20-08-2006, 4:26 PM
#6 (permalink)
| | Member
Thanks: Gave 9, Got 3 |
What is that cabinet? Looks pretty good, its not a b*stardised duoppli is it?
21-08-2006, 11:30 AM
#7 (permalink)
| | Prominent Member
Thanks: Gave 919, Got 472 | |
03-09-2006, 6:49 PM
#8 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Re: How do you lot *cope* with centre speakers ?
I ended up getting a sheet of mdf cut to the right size at b&q and for now it is stacked up on all my old videos until i find a unit that will do the job better.
10-09-2006, 6:18 PM
#9 (permalink)
| | New Member
well the rather crude solution i came up with was this |
10-09-2006, 10:46 PM
#10 (permalink)
| | New Member
In-wall? |
11-09-2006, 2:12 PM
#11 (permalink)
| | Prominent Member
Thanks: Gave 282, Got 322 | Re: How do you lot *cope* with centre speakers ?
Lovely adjustable middle shelf on Partington Minim AV rack.... the fact it's adjustable has been a complete godsend. The Monitor Audio RS LCR I upgraded to is bigger than the AE Evo one I had before. Quick adjustment of allen key on each corner and fits perfect again.
Pics to come later, but Centre speaker on A/V Rack shelf. Lovely.
Dan.
11-09-2006, 2:16 PM
#12 (permalink)
| | Ex Member
Thanks: Gave 147, Got 160 | Re: How do you lot *cope* with centre speakers ?
My 9830 has a lovely section between the display & the stand , perfect for my centre speaker.
12-10-2006, 1:03 PM
#13 (permalink)
| | New Member
Thanks: Gave 3, Got 1 | Re: How do you lot *cope* with centre speakers ?
Hi No3ntry
Have you moved on from having the shelf stood on videos yet? If so I'd be interested in seeing what you have done as I'm in a similar situation.
13-10-2006, 9:39 AM
#14 (permalink)
| | Member
Thanks: Gave 63, Got 3 | Re: How do you lot *cope* with centre speakers ?
Mine sits on top of my AV unit
__________________ TV: Panasonic 42PX60 DVD Recorder: Panasonic DMR EX85 AV Amp: Yamaha DSP Z9 Front Speakers: Monitor Audio GR60's Centre: Monitor Audio GR Centre Rear Speakers: 2 x Monitor Audio GR Centres Sub: BK Monolith DF |
15-10-2006, 12:10 PM
#15 (permalink)
| | Senior Member
Thanks: Gave 13, Got 51 | Re: How do you lot *cope* with centre speakers ?
Aah... I see you had the unit built Kroc Kroc. Looks really smart. What wood is it?
__________________ System: Linn, Audionote, Panasonic, Topfield, Revel, Various DACs; Cables: Atlas, AudioQuest & several home made; Furniture: Hold the Music; |
