Help? How much would you want to pay for an lcd wall mount
Old 13-05-2006, 12:13 PM   #1
piston broke's Avatar
3,046, Level: 12
Points: 3,046, Level: 12 Points: 3,046, Level: 12 Points: 3,046, Level: 12
Thanks: Gave 2, Got 3
serious question guys, my friend has an engineering company and was horrified at the cost of wall mounts for lcd's (even on ebay)-he has just knocked up a little prototype and was wondering how much to charge, so let me know your views and any sorts of ideal things to add please.
Ciurrently set up to take mounts on the rear of tv upto 280mm high and 220mm wide.
thanks very much
d
Old 14-05-2006, 10:05 AM   #2
4,893, Level: 16
Points: 4,893, Level: 16 Points: 4,893, Level: 16 Points: 4,893, Level: 16
Thanks: Gave 5, Got 42
Just charge a little less than Ebay and if your product is good and customer service is good you will be onto a winner!
This is a great market to be in as the number of LCDs or panels will skyrocket over the next decade.
