Originally Posted by Glenn Keen Thanks for that Mak99.
VERY nice! |
Glenn - you're welcome! The Synergy line also have a VERY high WAF!
In terms of housing a heavy amp, you could easily place the amp on the main bottom shelf, rated for 300 lbs. Even an intermediate (ie, internal) shelf is rated to hold up to 120 lbs with standard shelf pegs - or 150 lbs with heavy shelf bracket in lieu of pegs.
The beauty of a Twin unit is each bay's shelves can be individually spaced. So if you have a tall amp on the left side, it won't affect shelf spacing on the right side. So you can space out your gear and shelves so there's equal gaps between the top of the gear and the next shelf above. These racks are truly about as customizable as they come...
If you look at Salamander's original
Archetype line, you can see how you can easily make this design yourself with some threaded rods, nuts and washers. Of course, not nearly as nice looking as the Synergy line...
FYI, I am ONLY connected to Salamander as a very satisifed customer. If you had a local woodworker to make the main top and bottom shelves, you can buy the basic hardware (rails, shelf pegs, etc) from an eBay company called 80/20 Surplus. I recently bought some
extra rails from them (much cheaper than from Salamander) to convert my Twin20 to a Twin30 or Twin40.
- mark k.
