Alphason AG94/2 + Sony KDL-V32A12
Old 01-05-2006, 6:58 PM   #1
2,820, Level: 12
Points: 2,820, Level: 12 Points: 2,820, Level: 12 Points: 2,820, Level: 12
Activity: 12.8%
Activity: 12.8% Activity: 12.8% Activity: 12.8%
Thanks: Gave 22, Got 17
Question Alphason AG94/2 + Sony KDL-V32A12
I have a Sony KDL-V32A12 LCD television and am looking into getting a proper support for it to do the TV justice.
After having looked around, the Aragon AG94/2 looks perfect and is exactly what I am looking for.
I am unsure as to whether my TV is compatible with this support and, if possible, how easy/difficult it would be to mount it on the AG94/2.
I was hoping that anyone who has got a KDL-V32A12 mounted on this support would share their experiences. Did you need to buy anything other than the support itself i.e. extra brackets etc? Is it stable?
Obviously, all this is irrelevant if the TV can't be mounted at all. I have searched the forums but havent found the answer I was looking for.
Old 03-05-2006, 2:10 PM   #2
amgard's Avatar
3,583, Level: 14
Points: 3,583, Level: 14 Points: 3,583, Level: 14 Points: 3,583, Level: 14
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 118, Got 87
Sorry - I don't have any experience of that particular stand, but I have found Alphason's customer support to be very helpful.
That particular stand can be found at:
http://www.alphasondesign.co.uk/prod...2s/index.shtml
and you can email info@alphasondesigns.com for more specific help.
hth
Old 23-05-2006, 6:26 PM   #3
3,317, Level: 13
Points: 3,317, Level: 13 Points: 3,317, Level: 13 Points: 3,317, Level: 13
Thanks: Gave 128, Got 35
Sony do an AV stand especially for this type of TV...
check it out;
http://www.empiredirect.co.uk/conten...~make~Sony.htm
