AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
dekomount>TV Brackets >TV Wall Mounts
>LCD TV Bracket >DVD Brackets
LinkBack Thread Tools Display Modes
Old 29-04-2006, 1:43 PM   #1 (permalink)
Thanks: Gave 0, Got 40
Which TV / Media Stand is best for me?
I currently have:
sharp LC26P50E... Lcd TV
Cambridge Audio 540R... Reciever
Cambridge Audio 540C... cd player
Cambridge Audio 540D... dvd player
Panasonic DMRES20... dvd recoder
Sky Box
PS2
Centre Speaker
Can anyone recomend a stand for this lot. I currently have a very wobbly cheap stand. I dont want anything too expensive.
colinb07958 is offline
Old 29-04-2006, 2:06 PM   #2 (permalink)
yaser
Posts: n/a
The Schrores and ******** range is stunning, just purchased a piece myself.Great Quality
http://www.**********************/furn..._furniture.htm
Old 29-04-2006, 2:22 PM   #3 (permalink)
Looks very nice, but I cant see any prices
Old 30-04-2006, 8:38 PM   #4 (permalink)
I have seen these
http://www.ikea.com/webapp/wcs/store...61*15641*15962
Which one is best? also any other options?
Old 04-05-2006, 8:08 AM   #5 (permalink)
mundstick's Avatar
Thanks: Gave 23, Got 11
Ikea have a very well rated unit called "Oppli". If this doesn't have enough shelves you can fix two together.
Try this link
£55 Ikea AV Rack - 5 Star review!!!
I think the units cost about £56 each.
mundstick is offline
Old 04-05-2006, 8:29 AM   #6 (permalink)
Originally Posted by mundstick
Try this link
I really am stupid. I thought that the Dual Oppli was a seperate version. I didnt realise it was 2 joint together. Is that good value for £112 then? seems quite expensive
Old 05-05-2006, 2:22 PM   #7 (permalink)
mundstick's Avatar
Its not that expensive when you consider the size and the amount of storage you get with it.
There are cheaper options available,
try this
http://www.ebuyer.com/UK/product/95749/rb/18810244733
or this
Glass AV stand for £49 - Bargain!
It really is down to your own preference. Personally if I had the room I would be more than happy with a dual Oppli but sady it wont fit in the corner of my room
set
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
