Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
Caxton royale wide tv entertainment unit
Metropole Ocean TV entertainment unit
Caxton Coniston wide TV entertainment unit
The Furniture Factory Worcester TV En...
Caxton Coniston wide TV entertainment...
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
Wall mountable TV entertainment unit
 More...Prices updated November 23rd at 2:30pm and include delivery.
Old 26-04-2006, 12:36 PM   #1 (permalink)
Thanks: Gave 59, Got 39
Bespoke fitted furniture
Hi all,
I'm a self-confessed home cinema nutcase, who until very recently has been left to my own devices by the Mrs to enjoy my HC habit. I've been a serial lurker on this site, but thank you to those of you who regularily contribute as it's both informative and entertaining!
Unfortunately, she has now turned her attention to the sitting room (as we have finished renovating the rest of the house) and now she's seeking an "elegant solution" to house the plasma and the rest of the kit.
One of the Sunday magazines hosted an advert from Conquest-UK who seem to offer a bespoke fitted furniture service.
See this link for details (hope it works!): http://www.conquest-uk.com/rooms/ent.../lexington.htm
My old man is a joiner, and has offered his services to produce a unit of a similar design to the lexington. The issue is regarding the final finish. I don't really want a DIY brushed effect, but I can't see any alternative other than disassembling the finished unit and finding a friendly car body shop who would spray the components, that I could eventually reassemble back home.
Yes, I could use Conquest to do the entire job, but from their ballpark quotes it's either a few thousand quid with them, or a DIY job that may be several hundreds.
Can anyone offer any advice on obtaining a professional finish or alternative fitters?
CaptainCook is offline   Reply With Quote
Old 26-04-2006, 4:46 PM   #2 (permalink)
clockworks's Avatar
Thanks: Gave 64, Got 272
Buy a compressor and spraygun, and spray it yourself. You should be able to get a decent portable compressor and spraygun for under £250 from somewhere like MachineMart.
Spray painting isn't that difficult. The hardest part is getting the paint viscosity and air pressure correct. A few hours practice on scrap material should be enough.
Once you've finished the job, you can sell the equipment through your local paper or eBay - should get at least half your money back.
Panasonic TH-46PZ81B, Arcam AVR350, Linn LK100, Naim NAP110, Quad L-ites, PS3, Samsung 850, Sky+, Humax 9200T, Panasonic E50, Harmony 885, Pixel Magic HD-MB200, M-Audio Flying Cow DAC, Pronto TSU9600, Mac Mini, iMac Aluminium
clockworks is offline   Reply With Quote
Old 26-04-2006, 7:17 PM   #3 (permalink)
Thanks for the tip clockworks. £250 seems about right for a decent compressor and gun.
I'll have to be careful in the design not to expose too much "end-grain" of any MDF panels, as from experience these tend to soak up the paint like a sponge.
Got any further tips on sealing these those edges?
Also, if any other brave souls have gone down a similar route and want to offer any do's or dont's, feel free to shout out.
When I start the project, I'll open a thread in the DIY section.
CaptainCook
Old 26-04-2006, 10:03 PM   #4 (permalink)
shahedz's Avatar
Thanks: Gave 789, Got 425
i had bespoke cabinets and shelves made from MDF by a company called jali on www.jali.co.uk (or .com) , you download the designer and put in the dimensions and shelves you want, and they cut it to size and send it to you flat packed, i then had it painted, primar first then the paint.
check out the link below for pictures i posted earlier
Discreet Installation-cabinet Required
Linn Kolektor pre amp & LK140 amp,Genki,Sony MD MDS JE510,Sonos ZP80 + CR100,Ariston RD-40 turntable,TDL RTL3 ,Samsung32R87, Yamaha YSP-1000,Panasonic PT-AX100E projector,Toshiba HD-E1 ,Sky HD, PS3,Harmony 885
shahedz is online now   Reply With Quote
Old 27-04-2006, 11:45 AM   #5 (permalink)
Thanks for the link shahedz. Your finished cabinets do look great.
For the money it's an absolute no-brainer. The designer software is downloading as I type. By the way, did they use cam bolt type fixings?
Now having used them, and with the benefit of hindsight, was there anything you would have changed in your original design? For example, extra supports for the shelves?
I think I'll order the units and bookshelves to fill-in each side of the false chimney breast, then ask my dad to knock together a fly-over with downlighters linking them together.
Old 27-04-2006, 12:11 PM   #6 (permalink)
AMc
Thanks: Gave 10, Got 28
I have Jali cupboards fitted between the chimney breast in one room. IIRC they have cam bolts for the shelves, some pegs and you also need to do a fair bit of gluing. Mine were very large (bookshelves on cupboards) and my floor isn't flat (the house is >100 years old). This meant one of the cupboards didn't go together completely true which is a bit annoying but not Jali's fault.
Look carefully at their fittings for alcoves which remove the side trim at the skirting board level and extent the front side bars over the full distance. I chose this option but because I have skirting and picture rails I ended up with gaps anyway. In retrospect I would have been better off with the normal design.
I also made a schoolboy error and specified the wrong depth on one bookshelf which I had to bodge a bit to make them look even (there is a gap behind the shallower bookshelf).
One irritation with the designer software is you can't copy a unit and adjust just one dimension - you have to recreate from scratch. When creating two similar cupboards and two similar bookshelves to go either side this was a pain and lead to specifing the wrong trim on one. So choose their option to print, check and post you plans before manufacturing as it may save you an expensive mistake. They highlighted the trim issue - shame they didn't spot the depth error!
You will also get quite a shock when several KGs of flat pack MDF gets delivered. Their stuff is very heavy duty and you need some space to put it together!
Finishing took a while - mine were brushed with 2 coats of gloss which looks fine to me - but like all gloss took ages to do and ran a bit etc.
I'd certainly recommend them regardless - a good compromise between DIY and professional work at a fair price.
My Flickr Pictures
Philips Bogart DLP Projector-Sony KV32FX60U-Thomson Tivo-Wharfedale DV832BN(2) Freeview-Toshiba SD330E DVD-
-B-Tech Quintro+-Denon 2105 receiver-Canton CD1+CD50+CD100 Playstation3-Philips Pronto
AMc is offline   Reply With Quote
Old 27-04-2006, 12:34 PM   #7 (permalink)
shahedz's Avatar
Hi captain cook
to be honest i didnt put them together, so i havent got a clue about the fixings but hopefully AMC answered your questions.
i got the builder to install them and he done a fantastic job, he got some extra MDF and put the on the side so that they look like properly fitted,
with hindsight i would have matched the skirting, you can choose what height you want the skirting and had i matched it proerply it would have looked great, i wanted to paint the units white so they matched the existing skirting, but the females in the house out voted me on that , the builder ripped out the skirting round the sides and back of where the shelves would go so mine fit flush against the wall and have no gaps which i think gives it a slightly nicer look
i cant recommend them enough, extremly helpful. they did say if the unitts are more than 110cm wide the recommend a supporting pillar in the middle but mine were only 95cm wide, they are extremely strong. as you can see mine are loaded with books. but if you are loading yours with AV equipment i would recommend more shelves, if you want some pics of the internals or any extra pics drop me a PM and il email them to you,.
Old 27-04-2006, 12:45 PM   #8 (permalink)
Cheers AMc
Our house is a tad younger, and luckily the walls and floors are fairly true and square.
I'm gonna go for the alcove option, but I may have to scribe ever so slightly the side bar to fit the walls correctly. I'll also do this with the unit on the opposite wall, then the distance between the two units will determine the final width of the false chimney breast.
Without trying to drag this thread out much further, I couldn't see anything obvious on the Jali website to indicate the thickness of MDF they use. What thickness were your shelves?
Old 27-04-2006, 12:57 PM   #9 (permalink)
Cheers Shahedz
I've been tearing the skirting and architraves out as I decorate each room so I agree that incorporating the new "room" skirting into the units would help to integrate these units.
A base unit on one side will host the AV kit. The other side will be for DVD storage. The bookshelves on top of these units will probably be used for displaying a few decorative odds and ends.
Old 27-04-2006, 1:31 PM   #10 (permalink)
shahedz's Avatar
i'll measure the thickness tonight and get back to you, you can opt for a pillar inbetween the doors for added strength
Old 27-04-2006, 1:46 PM   #11 (permalink)
Slightly off-topic but just noticed the TDL RTL3's in your signature. I had a pair of these in mahogany a few years back and it's the only piece of kit that I regret selling. Lovely speakers.
Old 27-04-2006, 3:17 PM   #12 (permalink)
shahedz's Avatar
captain , i got them when i was 16! 9 years later i still cant bare to part with them, i love em, mine are the first edition with the full lenght grill but no plint, but the sound is fantastic!
by the way do you want me to take a close up of the paintwork on the shelf? i dont think you need a spray gun, because the builders done two coats or primer and 2 coats of paint and it is very , very smooth
Old 27-04-2006, 3:23 PM   #13 (permalink)
Yes please for the pictures.
My TDL's were the MK2's. Please don't bin em at any price!!
Old 27-04-2006, 7:47 PM   #14 (permalink)
shahedz's Avatar
Hi Captain
the MDF is 15mm thick, have attmepted to take photos but need to use the flash which causes a reflection il get some for you over the weekend .
Old 27-04-2006, 8:07 PM   #15 (permalink)
Thanks again.
bespoke, fitted, furniture
