Would this do the job ? Fully extended it may give you enough reach to look like it is in the corner.
www.vogels.com
EFW 6345
The EFW 6345 LCD/Plasma support is an 'optimally adjustable' wall support suitable for TVs up to 42”. It features tilt, turn and reach.
Flexibility and freedom of movement are the key benefits of the EFW 6345, as you can tilt and turn your screen any way you want for an optimal viewing experience. Don’t worry about damaging your screen or wall, either as the EFW 6345 features Vogel’s unique Screen Protection System (SPSTM) to protect both screen and wall.
