Wall Mount for LG LCD RZ37LZ31 - Can't find one!
Old 21-04-2006, 9:22 AM   #1
4,510, Level: 15
Points: 4,510, Level: 15 Points: 4,510, Level: 15 Points: 4,510, Level: 15
Thanks: Gave 2, Got 1
Question Wall Mount for LG LCD RZ37LZ31 - Can't find one!
Does anyone have the LG RZ-37LZ31 and more importantly have you managed to mount it on a wall?
The LG manual is no help at all in terms of recommended mounts and I searched for ages on the net to try and find one but can't be sure if it will fit.
Really need to know from anyone who has achieved this what bracket to use as its driving me mad (also was it easy to mount once you had the bracket?)
Can't see any other thread on this TV so hopefully it will be useful for others too.
Old 20-06-2006, 1:12 PM   #2
4,510, Level: 15
Thanks for posting JoshuaB. That site doesn't list measurements of the bracket so can't really be confident it will do the job .
Gone for this in the end as it was good price and seems to meet the sizes I measured up on the TV.
I'll update this post once I know if it works or not.
seccles12 (03-07-2006)
Old 23-06-2006, 12:06 PM   #3
4,510, Level: 15
looks like JoshuaB removed his post
Anways the BT8422 does the job a treat (link in my previous post). I hope this is useful for anyone else with this TV who wants it mounted.
Old 28-06-2006, 4:25 PM   #4
JoshuaB
Posts: n/a
not sure where my post went?? lol
but anyway glad you got it sorted. The Brackets are universal so should fit the stated tv sizes.
Measurements are being added soon to make it easier for customers to see etc.
Old 14-07-2006, 11:35 PM   #5
ricky100000
Posts: n/a
Try Taits
http://www.tait-components.co.uk/Pro...ck_code=168422
