need a unit for 32inch WS CRT TV
Old 19-04-2006, 10:26 PM   #1
3,828, Level: 14
Points: 3,828, Level: 14 Points: 3,828, Level: 14 Points: 3,828, Level: 14
Thanks: Gave 5, Got 8
hi, just got myself a 32inch widescreen CRT for my bedroom, description says it's 55Kg so i need a good unit that will take the TV. and i will also need it to hold a sky box/360/xbox1/ps2 and a cube.
so 4/5 shelves will be needed. not looking to spend too much and it's need to be quite small(in height) maybe 60-70cm's at a guess.
TV is a Thomson 32WM403 if that makes a difference.
http://www.argos.co.uk/static/Produc...nd%2Bunits.htm was looking at this but now i'm not sure if it would take the TV, as it looks quite flimsy
once i get this i just need to find space for the TV. think 28inch would have been better
