35 Kilo Wall Bracket... Bargain
Old 18-04-2006, 11:14 PM   #1
Steviebhoy's Avatar
2,220, Level: 10
Points: 2,220, Level: 10 Points: 2,220, Level: 10 Points: 2,220, Level: 10
Thanks: Gave 17, Got 13
Talking 35 Kilo Wall Bracket... Bargain
Have been looking for a wall bracket for my new JVC LT 37DS6BJ
About £50 for the cheapest £200 for an all singing, dancing one.....aye right I'm gonna pay that for a wall bracket...being an engineer, was going to make one up out of aluminiun... a bit of work but would be worth it...then was walking through Tescos on Saturday , noticed brackets for LCD's up to 35 Kilos for £20....bargain, bought it...hung it...no problems and far cheaper than anywhere else
Hope this help someone else
Old 30-04-2006, 11:08 PM   #2
6,490, Level: 19
Points: 6,490, Level: 19 Points: 6,490, Level: 19 Points: 6,490, Level: 19
Thanks: Gave 20, Got 7
Has your tv fallen down yet?
Which make/model is the bracket and how big is your tv? I assume it will be available in most Tesco's..?
Thx
ok, sorry, I see its a 37" tv you have...
Old 30-04-2006, 11:15 PM   #3
6,490, Level: 19
doesn't look like its available online.... http://www.tesco.com/electrical/brow...ockFlag|GTEQ+1
Old 01-05-2006, 12:05 AM   #4
Steviebhoy's Avatar
2,220, Level: 10
It was next to the LCD's on sale in the tesco Extra stores, sorry I never wrote the make and model.
I will find out the info when I'm at Tesco next
Old 02-05-2006, 1:10 AM   #5
4,518, Level: 15
Points: 4,518, Level: 15 Points: 4,518, Level: 15 Points: 4,518, Level: 15
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 10, Got 14
SteviebHoy,
I've got the same bracket - £19.99, came in a small box, very neat and holds the set close to the wall....
Been holding a 42" lcd set on a plasterboard wall for the past three months -
Absolute bargain!
Old 03-05-2006, 2:04 PM   #6
abr abr is offline
2,435, Level: 11
Points: 2,435, Level: 11 Points: 2,435, Level: 11 Points: 2,435, Level: 11
Thanks: Gave 5, Got 11
just bought one from tesco's stafford now reduced to £14.99.
need it to hold 40" sony lcd.
hope it will do the job.
it states 35 kilo
the sony is KDL S40
any thoughts on this
wil it or won't it do the job
arthur
Old 03-05-2006, 2:57 PM   #7
4,518, Level: 15
Activity: 0.7%
Arthur,
My Toshiba was 37 kilos (ish) but that weight included the stand.
I took the stand off and that weighed over 6 kilos on it's own, meaning the weight of the TV then was less than the maximum recommended...
Mine has held mine up on the wall for the past two months with no signs of it coming away....I did use several heavy duty bolts into the wall and pulled myself up on it before I risked the TV!
Old 03-05-2006, 5:53 PM   #8
abr abr is offline
2,435, Level: 11
@flashman.
many thanks for your reply
i think your lcd is about the same weight as the sony (its my son's)
i did intend putting strong rawbolts in the wall to hold it up.
arthur
Old 06-05-2006, 2:51 PM   #9
piston broke's Avatar
3,046, Level: 12
Points: 3,046, Level: 12 Points: 3,046, Level: 12 Points: 3,046, Level: 12
Thanks: Gave 2, Got 3
Currently on offer in the big newbury tesco's....£14 odd quid
every little helps
d
Old 07-05-2006, 7:19 PM   #10
paulroman34
Posts: n/a
For any one that's used these already(and maybe still has the packaging), will the hold a 43" Plasma (~30kg)?
thanks
Old 08-05-2006, 3:58 PM   #11
3,046, Level: 12
vesa 100 and 200 standards, if that helps
cheers
d
Old 08-05-2006, 8:20 PM   #12
paulroman34
Posts: n/a
Cheers, I copied the above info into a search engine and ended up at the link below
http://www.morpethmobiles.co.uk/prod...prod=MM740/X10
I assume this is it, although this add says the LCD TV is not included...daahhhh!! - and you'd have thought for £70 it was the least they could do.
Old 14-05-2006, 8:11 PM   #13
4,257, Level: 15
Points: 4,257, Level: 15 Points: 4,257, Level: 15 Points: 4,257, Level: 15
Thanks: Gave 7, Got 0
I have a 32inch Samsung LCD which i need to put on a plaster board wall. There is only one vertical joist behind plaster board which is positioned central to where i want to hang tv
Will this bracket be safe to use??
Also why is it so cheap whereas other bracket cost £50+
Old 22-05-2006, 11:34 AM   #14
3,046, Level: 12
Real bargain now-currently £9.97 in newbury, and it works a treat
Just had to enlarge the slots for the tosh-2 mins with a drill.
cheers
d
Old 22-05-2006, 4:23 PM   #15
superigor
Posts: n/a
vesa
will it do vesa 200 x 200 does anyone know ?
thank you
Old 23-05-2006, 8:12 AM   #16
3,046, Level: 12
vesa 100 and 200 compliant
d
