Mid Atlantic Racking
Old 15-04-2006, 5:38 AM   #1
4,276, Level: 15
Points: 4,276, Level: 15 Points: 4,276, Level: 15 Points: 4,276, Level: 15
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 30, Got 10
Anyone know where you can buy these in the UK. List of products and prices would be great. Thanks
Old 15-04-2006, 6:04 AM   #2
AVF Editorial Manager
Phil Hinton's Avatar
106,654, Level: 79
Points: 106,654, Level: 79 Points: 106,654, Level: 79 Points: 106,654, Level: 79
Activity: 14.4%
Activity: 14.4% Activity: 14.4% Activity: 14.4%
Thanks: Gave 1,069, Got 4,185
I beileve Invojo may supply this stuff. A quick google search will also bring up the UK distributers page. I am looking at a 19" rack system when i redesign my cinema room.
Old 15-04-2006, 8:19 AM   #3
Assured Advertiser
Joe Fernand's Avatar
36,526, Level: 46
Points: 36,526, Level: 46 Points: 36,526, Level: 46 Points: 36,526, Level: 46
Activity: 25.4%
Activity: 25.4% Activity: 25.4% Activity: 25.4%
Thanks: Gave 205, Got 1,344
Hello Steve Stifler
The Middle Atlantic racking has been available in the UK for a fair while now - its still relatively rare (and mostly used by Custom Installers) to find folk willing to invest in racking; which I find odd as once you've used it (especially so the pull out and or revolving models) you wouldn't want to be without it.
Most of the Middle Atlantic range is available in the UK - though not all of it is available 'from stock'.
Best regards
Joe
Old 15-04-2006, 1:52 PM   #4
4,276, Level: 15
Activity: 0.7%
Phil and Joe
Thanks for your responses. I have a feeling I need tostart saving. They do look good though. Maybe they have some options for cooling fans to keep everything running OK.
They always look great in the HCC install articles.
Old 15-04-2006, 10:13 PM   #5
4,725, Level: 16
Points: 4,725, Level: 16 Points: 4,725, Level: 16 Points: 4,725, Level: 16
Thanks: Gave 9, Got 34
RGB Communications are the UK distributor, http://www.rgbcomms.co.uk/
They should be able to put in contact with a dealer in your location.
Pemberto
