Lack
Old 14-04-2006, 8:56 PM   #1
DamoSXI
Posts: n/a
Lack
http://www.ikea.com/webapp/wcs/store...roductId=11317
Anybody use this as their LCD/Plasma stand ???
If so please post up some pixs !!!
Old 15-04-2006, 5:34 PM   #2
4,350, Level: 15
Points: 4,350, Level: 15 Points: 4,350, Level: 15 Points: 4,350, Level: 15
Thanks: Gave 0, Got 4
Won't that be a bit low?
For a few quid more you could get this - http://www.savastore.com/productinfo...0&pid=45&tid=3
if you're thinking of saving space.
Just an idea.....
Old 15-04-2006, 5:35 PM   #3
DamoSXI
Posts: n/a
Link doesnt work plus I want it that low !
Old 16-04-2006, 9:38 AM   #4
square-eyes-baz's Avatar
4,996, Level: 16
Points: 4,996, Level: 16 Points: 4,996, Level: 16 Points: 4,996, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 141, Got 139
Looked carefully at this myself(before buying an Oppli), only thing Id say is check the depth, tempting though.
The Oppli is 40cm high , the Lack is 35 cm, Baz
Old 16-04-2006, 11:01 AM   #5
DamoSXI
Posts: n/a
I like the style but I think I will get a unit made which looks similar
