Stand for 32WLT66
Old 13-04-2006, 2:05 PM   #1
supersons
Posts: n/a
Stand for 32WLT66
can anyone tell me if the stand for the TOSHIBA 32WLT58 fits the 32WLT66. If not does anyone know who has stock of the stand
Thanks, Martin
Old 16-04-2006, 10:50 AM   #2
4,659, Level: 16
Points: 4,659, Level: 16 Points: 4,659, Level: 16 Points: 4,659, Level: 16
Thanks: Gave 1, Got 5
i started the same post as i didnt see yours.I think i can get my hands on a 32wlt58 stand if i can talk my boss into giving it to me tomorrow.Not sure if it will fit thats why i wondered if anyone had tried it first.i will let you know in a few days.
Old 17-04-2006, 8:11 PM   #3
4,659, Level: 16
got the stand today but it is a slightly different mount at the back of the set and dont think it would be that easy to modify without making a new bracket
Old 17-04-2006, 9:48 PM   #4
supersons
Posts: n/a
Thanks for the info. I guess I will wait until I can get stand that fits prefectly
Thanks, Martin
Old 18-04-2006, 7:35 AM   #5
4,659, Level: 16
Im thinking of this one
http://www.argos.co.uk/webapp/wcs/st...o.x=10&go.y=12
Old 18-04-2006, 9:45 PM   #6
4,659, Level: 16
Took the tv off its own stand and i think you could unscrew the bracket and fit it to the wtl58 stand by drilling a few holes.I didnt want to take my stand to bits by the way but i think it should work.
Old 19-04-2006, 4:07 PM   #7
Prague1
Posts: n/a
How about buying the Toshiba stand for this TV?
http://www.empiredirect.co.uk/ and search for MV3WL66
I ordered one last night and got an email today saying it will be delivered tomorrow! For £118.64 plus £4.99 delivery it seems like pretty good value to me.
Just a shame that John Lewis can't deliver my new 32WLT66 until 2nd May....
Old 19-04-2006, 6:04 PM   #8
4,659, Level: 16
Thought about that but i prefered the 3 shelve stand.Fitted the one from argos and using the lower arms as a 3rd shelve.Looks pretty good
Old 19-04-2006, 6:50 PM   #9
Prague1
Posts: n/a
I was going for a stand where the TV simply stood on it but my missus is a cleaning fanatic and she would be pulling the damn thing out of the corner each week to vacuum. I just knew she'd topple the TV at some point!
At least using the Tosh stand the TV's actually attached!!!!
Anyway I''m calmly waiting for my TV to come and hoping it's as good as I've read about.....
Old 21-04-2006, 9:37 AM   #10
4,129, Level: 15
Points: 4,129, Level: 15 Points: 4,129, Level: 15 Points: 4,129, Level: 15
Thanks: Gave 4, Got 0
Pic of wl66 stand?
Has anyone seen any images of the wl66 stand?
Old 22-04-2006, 3:52 PM   #11
3,926, Level: 14
Points: 3,926, Level: 14 Points: 3,926, Level: 14 Points: 3,926, Level: 14
There's some on P12 and 13 of the main WL66 thread: The Toshiba 32/37WL66 & 32/37WLT66 thread
Personally, I think it looks awful and that the "58" stand was much better. The "58" stand doesn't accomodate the "66", which is giving me a bit of a dilemma as I want the TV, but hate the official stand.
Old 07-05-2006, 8:10 PM   #12
4,624, Level: 16
Points: 4,624, Level: 16 Points: 4,624, Level: 16 Points: 4,624, Level: 16
Thanks: Gave 2, Got 0
Does the official stand for the 32WLT66 come with all the screws needed to fix the LCD to it?
Anyone know?
Old 15-05-2006, 6:02 PM   #13
Prague1
Posts: n/a
Anyone know?
You don't need extra screws - basically the support for the TV on the official stand is the same as the tabletop stand which comes with the TV. You simply unscrew the tabletop stand and use the same screws to fit the set on the floor stand.
Hope this helps.
Old 13-06-2006, 7:55 PM   #14
5,045, Level: 16
Points: 5,045, Level: 16 Points: 5,045, Level: 16 Points: 5,045, Level: 16
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 72, Got 21
Could anyboy confirm whether the MV3WL66 stand has any kind of cable management in the rear support? Looking at the pictures it's difficult to see whether it's possible to hide the cables - the rear support seems to be solid.
Old 18-07-2006, 7:58 PM   #15
4,322, Level: 15
Points: 4,322, Level: 15 Points: 4,322, Level: 15 Points: 4,322, Level: 15
Activity: 0.5%
Activity: 0.5% Activity: 0.5% Activity: 0.5%
Thanks: Gave 6, Got 23
I had a look at this stand in local shop and can confirm there is a slot cut out at the back of the stand for cables to go through and then there are caps which go over the slot to keep it in place. However there are no holes from the shelves to get the cables through, they have to go around the side of the post.
I think I may buy one of these. Does anybody know the best price?
Old 18-07-2006, 8:53 PM   #16
4,377, Level: 15
Points: 4,377, Level: 15 Points: 4,377, Level: 15 Points: 4,377, Level: 15
Thanks: Gave 4, Got 1
Empire direct i`m sure is the best price mate at £123 all in.
