Kenmark KM-TS02M £45 in Argos
Old 29-03-2006, 6:29 PM   #1
Papacino
Posts: n/a
A week ago I bought the Kenmark KM-TS02M from John Lewis for £79.95;
http://www.johnlewis.com/Audio+and+T...5/Product.aspx
The next day I saw this Matrix stand in Argos for £44.99;
http://www.argos.co.uk/static/Produc...er/6108009.htm
It looked identical in the pic and was the same dimensions. I contacted John Lewis undersales to try and get a price match, but they refused, saying that to their knowledge Kenmark did not supply Argos.
Today I purchased the Matrix stand from Argos. It is exactly the same model - it even has the KM-TS02M code on the packaging inside. Called John Lewis back and they are looking into it, but in the meantime they agreed to let me return the Kenmark stand for a refund.
I am using this stand with my Samsung LE32R41BD and it looks excellent. A classy stand at a bargain price!
Bizness (04-04-2006)
Old 29-03-2006, 8:53 PM   #2
3,974, Level: 14
Points: 3,974, Level: 14 Points: 3,974, Level: 14 Points: 3,974, Level: 14
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 20, Got 15
Good spot ! I was thinking of getting the John Lewis one but I think I'll get one of these.
Could you by any chance tell me the measurement between the shelves.
Old 29-03-2006, 9:41 PM   #3
Papacino
Posts: n/a
chrisowe, the measurements are 18.5cm bottom to middle, and just under 20cm middle to top.
chrisowe (30-03-2006)
Old 30-03-2006, 8:29 PM   #4
3,534, Level: 13
Points: 3,534, Level: 13 Points: 3,534, Level: 13 Points: 3,534, Level: 13
Thanks: Gave 40, Got 32
Cool,
Can you tell me how wide it is between pillars at the back please?
I think I'll pick one up asap..
Old 30-03-2006, 9:02 PM   #5
Papacino
Posts: n/a
Originally Posted by RunDMC
Cool,
RunDMC, the distance between the pillars at the back is 41.5cm.
egraphix (30-03-2006), RunDMC (30-03-2006)
Old 30-03-2006, 9:18 PM   #6
3,534, Level: 13
Thanks, Papacino.
It appears that my recorder won't fit between the pillars (damnit). Could you let me (actually, her indoors) know the distance from the front of the rear pillar to the front of the shelf please?
Sorry to be a pain...
Old 30-03-2006, 9:25 PM   #7
Papacino
Posts: n/a
That distance is just over 32cm. My DVD player doesn't fit between the pillars, but fits with room to spare between the front of the rear pillars and the front of the shelf.
Old 30-03-2006, 10:06 PM   #8
3,534, Level: 13
Many, many thanks for your endeavours (the missus thanks you too)...
Old 02-04-2006, 7:03 PM   #9
coldcut
Posts: n/a
Talking
Thanks for the info about this stand i got 1 today fantastic value for a quality stand
THANKS
Old 03-04-2006, 4:48 PM   #10
4,396, Level: 15
Points: 4,396, Level: 15 Points: 4,396, Level: 15 Points: 4,396, Level: 15
Thanks: Gave 2, Got 6
I would of got this stand as it's a great price, unfortunately it won't fit my av amp, dvd player and centre speaker so I've had to buy a £250 stand instead. Didn't realize I'd have to spend so much to get a suitable stand.
Old 04-04-2006, 7:10 PM   #11
3,974, Level: 14
Activity: 0.8%
I know what you mean my amp won't fit either. I will have to get the £149 one from Richer Sounds instead.
Old 05-04-2006, 1:04 PM   #12
Bizness's Avatar
6,876, Level: 19
Points: 6,876, Level: 19 Points: 6,876, Level: 19 Points: 6,876, Level: 19
Thanks: Gave 152, Got 200
Went in Argos today and it's not in the catalogue will order off the web I think.
Nice one for pointing this out though
Old 05-04-2006, 8:46 PM   #13
3,974, Level: 14
Activity: 0.8%
It's probably not in the regular catalogue, but it is in the Argos Extra catalogue don't know what page number though.
Bizness (06-04-2006)
Old 06-04-2006, 10:57 AM   #14
4,461, Level: 15
Points: 4,461, Level: 15 Points: 4,461, Level: 15 Points: 4,461, Level: 15
Thanks: Gave 1, Got 2
Great find-I got one yesterday and its very impressive.
I got it from an "extra" store but reserved it online first. I don't know what the page number is either but you could just reserve it first like i did. (It does a stock check too so you dont waste time going there to find it out of stock etc)
The shelves take my Xbox and Sky box with ease-plenty of room front and back, and the whole thing feels solid/well built. It looks like it cost a hell of a lot more too.
Any pics/measurements etc needed give me a shout
Old 06-04-2006, 11:41 AM   #15
Bizness's Avatar
6,876, Level: 19
Reserved
Old 06-04-2006, 7:00 PM   #16
4,396, Level: 15
I've just bought a stand for £250 and I've just found out it weighs 38kg
Are all tv stands with glass shelves this heavy? I'm going to have to send it back as it's too heavy for me.
It's becoming a bit of a nightmare this trying to find a suitable stand for my av equipment and tv.
Old 07-04-2006, 6:36 AM   #17
7,527, Level: 20
Points: 7,527, Level: 20 Points: 7,527, Level: 20 Points: 7,527, Level: 20
Activity: 0.8%
Thanks: Gave 3, Got 90
Don't know how you lot manage to fit all your stuff on only 3 shelfs I need 4 maybe more easy.
Xb360
XB
Video Player
Sky+
HTPC
HDTV
Can't find any that can fit all my stuff anyone know of any?
Old 07-04-2006, 12:34 PM   #18
inzaman's Avatar
22,352, Level: 36
Points: 22,352, Level: 36 Points: 22,352, Level: 36 Points: 22,352, Level: 36
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 126, Got 543
Wow thats over half my body weight
Whats it made of?
Old 07-04-2006, 3:15 PM   #19
4,396, Level: 15
Wood and glass. I can hardly move the damn thing nevermind put it together.
Old 10-01-2007, 9:17 AM   #20
4,971, Level: 16
Points: 4,971, Level: 16 Points: 4,971, Level: 16 Points: 4,971, Level: 16
Thanks: Gave 5, Got 6
Re: Kenmark KM-TS02M £45 in Argos
Gotta love this place... quick search on here after finding a stand I likes in Comet for 130+ quid... and I get it for 45! Nice!
At that price is was wife friendly too!
Old 11-01-2007, 11:38 AM   #21
2,522, Level: 11
Points: 2,522, Level: 11 Points: 2,522, Level: 11 Points: 2,522, Level: 11
Thanks: Gave 21, Got 29
Here is another one on Argos with more shelves:
http://www.argos.co.uk/webapp/wcs/st...hTerms=6108566
Glass and metal unit with chrome tubular legs.
3 internal shelves and top shelf.
Largest internal dimensions for Hi-Fi equipment (W)46, (D)33, (H)21.7cm.
Overall size (W)60, (D)45, (H)59.5cm.
Old 06-01-2008, 6:43 PM   #22
4,619, Level: 16
Points: 4,619, Level: 16 Points: 4,619, Level: 16 Points: 4,619, Level: 16
Thanks: Gave 1, Got 0
I love the Internet
I bought one of these Kenmarks in early '06 from John Lewis for £60, and wanted another one now for the bedroom. JL no longer sell them but I was told Comet do.
Popped along £150 but only £75 if I buy a TV from them, all that told me was at £75 they were still making a profit Ideally I wanted the 60cm but through a bit of searching found out that Argos sell it under the Matrix name for £40
