help finding a floating plasma stand cheap
Old 25-03-2006, 3:31 PM   #1
HOWDINSKI
Posts: n/a
does anyone know where i can get a plasma stand capable of holding a 50" pioneer 506xde?
At reasonable price no more than £500 if possible
Thank's all
This is the style i am after.
or this
or this
http://www.audiovisiononline.co.uk/erol.html
THE LINK ABOVE I MEAN THE TRISCOM PL 140 OR THE TRISCOM WALL.
Old 26-03-2006, 7:54 PM   #2
HOWDINSKI
Posts: n/a
Old 27-03-2006, 7:15 PM   #3
6,368, Level: 19
Points: 6,368, Level: 19 Points: 6,368, Level: 19 Points: 6,368, Level: 19
Might not be a perfect fit for your style but try item code DSK-STD-PLASMA
at www.aria.co.uk.
I've attached a piccie.
Only 210 quid though!
Bren
HOWDINSKI (04-04-2006)
Old 29-03-2006, 11:01 PM   #4
HOWDINSKI
Posts: n/a
Thank's mate. It's nice but i'm not sure about the idea of the grippers holding the edges of my piano black plasma.
But thank's for taking the time to help
Old 31-03-2006, 12:28 PM   #5
vex vex is offline
10,368, Level: 24
Points: 10,368, Level: 24 Points: 10,368, Level: 24 Points: 10,368, Level: 24
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 27, Got 252
You could try here for a very wide range.
http://www.homecinemastands.co.uk/
Old 31-03-2006, 5:34 PM   #6
9,163, Level: 22
Points: 9,163, Level: 22 Points: 9,163, Level: 22 Points: 9,163, Level: 22
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 217, Got 360
http://www.unicol.com/ - the Axia isn't cheap, but it's bulletproof, heavy, made in the UK and pretty awesome looking
