Wall mount for Phillips 30" LCD
Old 24-03-2006, 6:25 PM   #1
Whity74
Posts: n/a
im after a wall bracket for a 30" Phillips LCD, im after one that can pull out and that you can aim in different directions in the room. What would you recomend?
thanks
Old 24-03-2006, 7:23 PM   #2
vex vex is offline
10,368, Level: 24
Points: 10,368, Level: 24 Points: 10,368, Level: 24 Points: 10,368, Level: 24
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 27, Got 252
Hi Whity,
What mounting does your Philips have?
Is it a VESA standard with either 75, 100 or 200mm hole spacings?
If so, then a Premier Mounts AM-2 will do perfectly.
Old 25-03-2006, 6:28 PM   #3
Whity74
Posts: n/a
it just says flat screen on the tv not sure exactly the model??
it came with a wall bracket thats just a sheet of aluminum with 2 holes in it but i want and be able to change the angle ect, do u know what i would need and wheres best to get one from??
thanks
