will this fit ?
Old 22-03-2006, 2:14 PM   #1
4,042, Level: 14
Points: 4,042, Level: 14 Points: 4,042, Level: 14 Points: 4,042, Level: 14
Thanks: Gave 1, Got 0
will this fit ?
will a 200x100 vesa wall mount work with my samsung LE26R41BD ,
on the samsung website under specifications it says to get the 200*200mm wall mount for the tv, but they are quite expensive, but ive found a 200x100 quite cheap i might buy.
or if anyone knows somewere with a cheaper one then drop the link and it wlll be much appreciated..
sorry if this has been asked before but i gotta know
thanks.
Chris
