Stil Stand STUK2052
Old 21-03-2006, 10:02 AM   #1
4,055, Level: 15
Points: 4,055, Level: 15 Points: 4,055, Level: 15 Points: 4,055, Level: 15
Post Stil Stand STUK2052
I was wondering if anybody uses the above stand, i'm considering using it on my Samsung LE32R41BD. The only reason why i'm considering it, is becuase i live in a rented house and can't drill holes in the wall for a wall mount.
http://www.stil-stand.co.uk/stuk2052.htm
Old 21-03-2006, 12:51 PM   #2
7,917, Level: 21
Points: 7,917, Level: 21 Points: 7,917, Level: 21 Points: 7,917, Level: 21
Thanks: Gave 22, Got 15
Hi mate I use a STUK 2053. Great looking product.
Old 22-03-2006, 7:53 PM   #3
4,055, Level: 15
Thanks for the reply did you build it up yourself or did you get it ready made?
Regard
J
