Need help with a 900mm AV rack
Old 01-01-2006, 12:38 PM   #1
7,473, Level: 20
Points: 7,473, Level: 20 Points: 7,473, Level: 20 Points: 7,473, Level: 20
Thanks: Gave 14, Got 83
Hi my fellow AV enthusiasts
Circumstances have arisen where i have to take my plasma off the wall and have it on a stand, now i need it to be able to fit it partly in a 930mm alcove at a slight angle. Can anybody recommend a rack suitable for my needs, 900mm is about the max width so i can just get two AV products side by side. It also needs to have three shelves a bottom middle and top, i would also prefer glass shelves with a silver metal frame.
As and when i get a suitable stand i will have for sale a stunning Mirage all glass AV rack
Can anybody help
rergards Shaun (happy new year to you all)
Old 01-01-2006, 7:24 PM   #2
4,444, Level: 15
Points: 4,444, Level: 15 Points: 4,444, Level: 15 Points: 4,444, Level: 15
Thanks: Gave 5, Got 3
Hi Shaun.
This Optimum rack is 800mm wide, so might be too narrow for you:
http://www.petertyson.co.uk/optimumlcd8003sl.shtml
