Wide Cabinet - help???
Old 31-12-2005, 11:32 AM   #1
4,292, Level: 15
Points: 4,292, Level: 15 Points: 4,292, Level: 15 Points: 4,292, Level: 15
Activity: 4.7%
Activity: 4.7% Activity: 4.7% Activity: 4.7%
Thanks: Gave 21, Got 12
I'm trying to find a wood cabinet which is wide enough to hold 3 standard-sized components, and needs to be glass doors (ideally frosted / tinted).
Size-wise, width 140-160cm, depth 45-60cm, height 60-100cm.
Any help would be most appreciative...!
Old 31-12-2005, 1:28 PM   #2
Conspicuous Member
shahedz's Avatar
13,128, Level: 27
Points: 13,128, Level: 27 Points: 13,128, Level: 27 Points: 13,128, Level: 27
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 1,382, Got 724
try www.jali.co.uk
they can custom build a cabinet to suit your spec, although you would need to source the glass from a galziers to do the the inset on the door yourself
