wall bracket for a Kef iQ6C?
Old 17-11-2005, 11:06 PM   #1
4,736, Level: 16
Points: 4,736, Level: 16 Points: 4,736, Level: 16 Points: 4,736, Level: 16
Thanks: Gave 1, Got 6
Hi lads,
So, this centre speaker ia a huge 9kg one and it measures 16,9x51,3x22,5cm.
I have a Sony Bravia LCD on the rack, making impossible to rest the speaker under the LCD as it would block a good part of the screen.
Above is the solution, but how?
Any bracket, stand, etc, that allows me to put it on the wall, even better if i can rotate it a little bit down to point to the couch?!
Thanks in advance
