wall mount help needed
Old 17-11-2005, 2:23 PM   #1
waterloo's Avatar
5,018, Level: 16
Points: 5,018, Level: 16 Points: 5,018, Level: 16 Points: 5,018, Level: 16
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 51, Got 11
hi can anybody tell me if i can mount my sons 15in crt portable tv on a wall mount that says its suitable for tvs up to 14in. its only 1 inch bigger plus no heavier and was wondering how these work any help on this one thanks
Old 17-11-2005, 2:39 PM   #2
waterloo's Avatar
5,018, Level: 16
Activity: 0.7%
somebody must no ???
Old 17-11-2005, 7:26 PM   #3
3,014, Level: 12
Points: 3,014, Level: 12 Points: 3,014, Level: 12 Points: 3,014, Level: 12
Thanks: Gave 6, Got 25
If its not any bigger then yes you can put it up. its a weight thing and if its no heavier and fits then go for it.
Old 17-11-2005, 9:08 PM   #4
inzaman's Avatar
22,352, Level: 36
Points: 22,352, Level: 36 Points: 22,352, Level: 36 Points: 22,352, Level: 36
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 126, Got 543
I too would imagine its based more on a weight thing, if the TV is no heavier than recommended and it is sturdy when on the mount then as above.
Old 17-11-2005, 10:13 PM   #5
waterloo's Avatar
5,018, Level: 16
Activity: 0.7%
thats just what i thought about the weight thing not so much the size i will put up and let you no thanks for you help.
