Which wall mount for the LG LG 32LX2R?
Old 13-11-2005, 10:09 PM   #1
2,471, Level: 11
Points: 2,471, Level: 11 Points: 2,471, Level: 11 Points: 2,471, Level: 11
Thanks: Gave 12, Got 7
Which wall mount for the LG 32LX2R?
Just ordered this set, but can't find anywhere that says which wall mounts will be suitable for it. I'm not after a bracket that can swivel, just one thats sturdy and cheap
Any advice would be appreciated!
Old 03-01-2006, 5:54 PM   #2
zzchess
Posts: n/a
In the same boat here - anyone got an answer?
Old 04-01-2006, 12:32 AM   #3
2,946, Level: 12
Points: 2,946, Level: 12 Points: 2,946, Level: 12 Points: 2,946, Level: 12
Thanks: Gave 1, Got 2
hi guys, comet do a fixed wall mount for between £60 and £90. i know this because my brother installs lcds etc and he buys the mounts for that particular tv only from comet cos that was the only bracket he could find with 6 fixing holes at that size. hope this helps, thanks, pete
