11-11-2005, 7:37 PM
#1 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Argos chairs
Pages 216-217
Does anyone have any experience with these chairs(or know of any reviews on them)
Specifically item 4 on page 216(id buy it but those bent wooden arm/legs things look kinda fragile.)
And items 7 on page 217.
-Mic-
13-11-2005, 11:57 AM
#2 (permalink)
| | Member
Thanks: Gave 4, Got 2 |
If u post the item no. or maybe some weblinks to the argos site, i'm sure you'll get a better response. |
13-11-2005, 1:22 PM
#3 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | |
14-11-2005, 7:04 PM
#4 (permalink)
| | Senior Member
Thanks: Gave 23, Got 15 |
Hi Optimal
If your worried about them being fragile, How about the these they look quite good. http://www.argos.co.uk/static/Produc...e%2Bchairs.htm
__________________ My Set up: Panasonic AE2000, PHD8 50" US PS3, Toshiba EP30 Shanling CD-S100, Onkyo 876 , LCR PMC TB2+, M&K K4, Sky HD, Velodyne Digital Drive 18, |
14-11-2005, 9:41 PM
#5 (permalink)
| | New Member
My brother has the a similar thing (bought from argos a few years ago, changed a bit since)
Its nice but i dont like the design if im being completely honest. I dont think it would fit in with the design of my room.
Thanks for the tip however
20-11-2005, 5:20 PM
#6 (permalink)
| | Prominent Member
Thanks: Gave 128, Got 466 |
I got this of ebay at just over £55 delivered, its very comfy, as you can see just in the process of decorating.
My flickr Pentax K20D/ K10D Sigma 10-20mm/Tamron 70-300mm/Pentax 50mm f1.4/Sigma 24-70mm DG-EX MyA/V
"Chance favors the prepared mind"
20-11-2005, 5:36 PM
#7 (permalink)
| | New Member
Well i caved and bought a much cheaper chair, it doesnt look as good but I like it, will post pics Thursday when its delivered.
22-11-2005, 2:31 PM
#8 (permalink)
| | Senior Member
Thanks: Gave 28, Got 123 |
I have this:
and this
Reaaly pleased with them from IKEA.
22-11-2005, 4:33 PM
#9 (permalink)
| | Member
Thanks: Gave 0, Got 1 | Quote: |
Originally Posted by sbowler I got this of ebay at just over £55 delivered, its very comfy, as you can see just in the process of decorating. | Where did you get those bookcases from? I like them.
26-11-2005, 9:10 PM
#10 (permalink)
| | Member
i have 2 of the exact setup of them chairs , and to be honest mate there in the loft , there ok to use now and again but the foam in them caves in within a few months and to clean up THERE A PAIN IN THE ARSE (you have to take them fully apart to get fabric of)
trust me spend money else where ... unless you get the leather ones then you wont have to wash them just wipe , but still the foam is crap
Gamertag :ManThatYouFear
