damn it. this is perfect... BUT!!!!
Old 29-10-2005, 10:50 PM   #1
5,780, Level: 18
Points: 5,780, Level: 18 Points: 5,780, Level: 18 Points: 5,780, Level: 18
Thanks: Gave 4, Got 1
the exact thing i'm after
but look at the price!!!!!
i've got about £150 to spend if anybody has seen anything like this. due to space it needs to be about the same dimensions.
cheers
Old 29-10-2005, 10:54 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
http://www.arcafurniture.co.uk/c32/Arca_Nuevo_Range.htm
Old 31-10-2005, 8:21 AM   #3
4,893, Level: 16
Points: 4,893, Level: 16 Points: 4,893, Level: 16 Points: 4,893, Level: 16
Thanks: Gave 5, Got 42
You will have to either up your budget or build it yourself or go to your local carpenter and get a quote.
IN YOUR PRICE RANGE:
Wickes, B & Q , Argos, Ikea.
For a little more, try jali.co.uk.
My price range list is here:
BIG dvd cabinet needed!
