Billy Bookcase Dimensions
Old 21-04-2005, 6:16 AM   #1
5,101, Level: 16
Points: 5,101, Level: 16 Points: 5,101, Level: 16 Points: 5,101, Level: 16
Thanks: Gave 18, Got 25
Question Billy Bookcase Dimensions
Can someone please post the internal dimension of a 106cm high x 80cm wide billy bookcase.
I am after the internal width, depth and height.
cheers
Vinesh
Old 21-04-2005, 10:35 AM   #2
vizslaraner's Avatar
9,139, Level: 22
Points: 9,139, Level: 22 Points: 9,139, Level: 22 Points: 9,139, Level: 22
94cm high x 76cm wide x 26cm deep (give or take the odd few millimetres).
Old 21-04-2005, 3:42 PM   #3
5,101, Level: 16
Cheers mate.
Thats what I need to calculate how many DVD's I can fit.
Old 25-04-2005, 9:23 PM   #4
25,079, Level: 38
Points: 25,079, Level: 38 Points: 25,079, Level: 38 Points: 25,079, Level: 38
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 51, Got 1,049
out of interest how many will it take?
Old 26-04-2005, 5:50 AM   #5
5,101, Level: 16
About 250
If the DVD's are double stacked, ie on top of the row then more can be fitted. I am buying the billy bookcase this week. I will post a actual figure end of next week.
Old 26-04-2005, 9:33 AM   #6
25,079, Level: 38
Activity: 3.8%
that's the little one isn't it? I'm going to get the larger one and hope to get some books in too.
Old 26-04-2005, 9:42 PM   #7
Lancia34's Avatar
8,039, Level: 21
Points: 8,039, Level: 21 Points: 8,039, Level: 21 Points: 8,039, Level: 21
Activity: 15.9%
Activity: 15.9% Activity: 15.9% Activity: 15.9%
Thanks: Gave 96, Got 228
I bought 3 of these not long ago. Havent got the dimensions but I got an extra shelf for each one so basically I have 4 rows each holding about 50 DVDs (600 for all 3 bookcases - the wide billy, not the narrow one).
Good thing about the Billy bookcases is that they are well made & you can get doors for them (although the doors end up costing more than the bookcases but look great. You can also extend upwards as well - after a lot of searching they seemed the most versatile for the price.
Old 26-04-2005, 10:00 PM   #8
25,079, Level: 38
Activity: 3.8%
Actually I might as well ask my question here and get redirected to the right forum, if one exists.
I want to use a large Billy with doors for DVD and book storage, nothing complex there except I want to mount it off the ground and I don't know what fixings I'd need to do it - can anyone advise? I assume I'll have to create a "shelf" for the bookcase to stand on and then something simple to retain the top to stop it tipping.
I assume these things weigh about 30Kg** and complete with DVDs and books it could rise to 80+kg. I should explain I want to mount it in an alcove on a stairway and it will only fit if I raise it above the stair treads, hence the need to mount it on the wall.
Any suggestions?
**Just checked the Ikea website and the combo starts at 45kg before adding contents so probably 100kg when on the wall!
Old 07-05-2005, 10:03 AM   #9
6,794, Level: 19
Points: 6,794, Level: 19 Points: 6,794, Level: 19 Points: 6,794, Level: 19
Thanks: Gave 23, Got 3
The bill range is unbeleivable! I have got one of the 7 footish wide cabinets ! I added 2 extra shelves and the doors (yes you can do it!) and it now holds every video and dvd i own! It is brilliant! Highly recommended!
Old 07-05-2005, 3:24 PM   #10
5,101, Level: 16
I have gone for the shorter cases.
I can easily fit 200 within one case. I have also gone for the solid doors.
See Pics:
