Help - Stand or wall mount Philips 42 plasma
Old 12-04-2005, 9:57 PM   #1
sneale's Avatar
8,169, Level: 21
Points: 8,169, Level: 21 Points: 8,169, Level: 21 Points: 8,169, Level: 21
Thanks: Gave 1, Got 5
I have a Philips 42PF9952 which i require a desktop stand or a wall mount.
The usual Philips stand is not compatable as it seems there were 2 versions of this model with the same number but different backs. I have a pic of mine below and would be very grateful if anyone could offer any advice
attachmentid=12344&stc=1[/IMG]
Old 27-09-2005, 12:16 AM   #2
sneale's Avatar
8,169, Level: 21
Old 05-10-2005, 10:31 AM   #3
bobbypunk
Posts: n/a
check out www.vogles.com they offer universal desktop stands and numerous wallmounts with a "Will it fit? checker". All good quality stuff!
