Help!!
Old 09-03-2005, 5:20 PM   #1
montymole
Posts: n/a
Help!!
Hi there,
I'm trying to find some form of Hi-Fi Rack with at least 4 shelves, but it has to be able to take a couple of Niles Multi-zone Receivers, which are approx 18.5cm in height, 43cm width & 42.5 Depth. Which, seems to rule out most of the usual brands of racks. The only one that I've found so far, that seems to fit my specs is a Target S230; but I wondered if anyone out there knew of any other suitable racks.
Appreciate, any help you can give.......I'm new to all this!
Many Thanks.
Old 09-03-2005, 5:31 PM   #2
3,175, Level: 13
Points: 3,175, Level: 13 Points: 3,175, Level: 13 Points: 3,175, Level: 13
Thanks: Gave 1, Got 1
Try Optimum (www.optimum2000.com) their racks are modular, and you can choose your own shelf heights. The offer rods from 80mm up to 600mm.
The 200mm rods would meet your amp requirements, and the stand is 1.1M wide and 500mm deep.
I've just bought one .... see my Optimum Thread.
OK this is an AV rack ... but I'm sure their HiFi racks are just as modular.
