Equinox AV 3 shelf stability?
Old 03-03-2005, 3:53 PM   #1
4,547, Level: 15
Points: 4,547, Level: 15 Points: 4,547, Level: 15 Points: 4,547, Level: 15
Activity: 28.8%
Activity: 28.8% Activity: 28.8% Activity: 28.8%
Thanks: Gave 93, Got 123
Question Equinox AV 3 shelf stability?
Giving some serious thought to either the Equinox AV (3 shelf) or Optimum AVFF3 for a 50" plasma, centre speaker, amp etc etc.
The only thing that concerns me about the AV is the fact that the top shelf is an add-on module - can anyone in the know say how stable this is? Against "nudges" and so on - don't really want an expensive TV crashing to the floor obviously.
Cheers!
P.S. Or am I completely off-course for a decent glass stand system? Would consider other alternatives.
Old 03-03-2005, 4:21 PM   #2
masped
Posts: n/a
Hi, I have the 3-shelf version of the Equinox AV stand. I can assure you that it's extremely stable - the carpet spikes supplied with the add-on shelf fit into holes in the top of the base unit so it doesn't move if you bump into it. On the other hand, a 50'' plasma will likely overhang the edges of the stand by quite a margin (my 37'' Viera is exactly the same width as the stand) so you'll need to be careful you don't knock into the TV itself.
HTH,
masped
Old 04-03-2005, 12:28 PM   #3
4,547, Level: 15
Activity: 28.8%
Thanks very much for the reply. Yeah, I know about the overhang but I have yet to see a stand that's over a metre wide!
BTW, are you happy with the kit?
Cheers,
Richard
Old 04-03-2005, 1:04 PM   #4
masped
Posts: n/a
Yes, very happy - it's well made, looks good and has plenty of space for all my kit.
Old 04-03-2005, 7:04 PM   #5
Fahad
Posts: n/a
Do you mind telling me where you bought it from as I'm interestd in the 2 shelf model.
Fahad
Old 04-03-2005, 8:14 PM   #6
masped
Posts: n/a
From Peter Tyson - they were very easy to deal with . Here's a link to their prices (delivery is extra):
http://www.petertyson.co.uk/atacamaequinox.shtml
Old 05-03-2005, 12:53 AM   #7
Fahad
Posts: n/a
Thanks. One thing I can't get. The top shelf can take 75 kilos if you just buy the first piece which has 2 shelves. But what happens if you buy the add on shelf, does the now 2nd shelf still carry 75 kilos?
Old 05-03-2005, 8:47 AM   #8
masped
Posts: n/a
No, I don't understand that either. There doesn't appear to be any difference between the shelves themselves. I'm taking the weight limits to mean no more than 125kg across all 3 shelves, with a maximum of 75kg for any individual shelf.
