Urgently Need a Low TV Stand
Old 25-05-2012, 6:41 AM   #1
I urgently need a low tv stand, no more than 26cm high. Preferably it should be a corner unit and preferably it should have a shelf. I have tried searching the internet and can't find anything that low. Without it I am really constrained with what new TV I have. I about to replace my old CRT and to get what I want the stand needs to be no more than 26cm high. Anyone got any ideas ?
Old 02-06-2012, 11:54 AM   #2
Thanks: Gave 49, Got 35
We've just been through the same thing - Look at techlink products - they're a little higher than you want but not much and do a corner unit variant too, though in the end we went for a straight one and settled for rotating the tv on it's stand - takes up much less space that way.
http://www.techlink.uk.com/products/...d_plasma_stand
Old 16-06-2012, 9:26 AM   #3
Thanks: Gave 0, Got 6
How can you fit an AVR in tht stand? Notice with alot of stands there is no height between shelves, I'm struggling to fit an onkyo 609 in a stand!! No shelf is big enough
Old 18-06-2012, 9:20 AM   #4
I haven't got an AVR - and you're right, one wouldn't normally fit. My stand currently holds an HTPC, amp, DAC, modem, router, V+ box, DVD player and a couple of boxes of 3d specs.
The glass shelf in the middle is kind of optional; if you needed the extra height you could leave it out altogether.
