Ikea Best - Where to Put the Centre Speaker ?
Old 09-05-2012, 9:27 AM   #1
Thanks: Gave 1, Got 7
We've got a Besta TV cabinet / stand set-up (see picture, although since this picture was taken we've got a nice black tv one extra balck cupboard on the end).
You may see in the picture the rather lonely looking Kef eggs on top. I would really like to be able to bring them down and mount them at a more sensible hieght. Unforunately all the Ikea Besta stuff seems to have a vertical support down the middle of the cabinet, which is in the way of the centre speaker.
Does anyone have any suggestions or best modifications that have worked ?
(don't know what's up with that picture link - maybe you have to be logged into skydrive - https://skydrive.live.com/redir.aspx...CsyRkN80n97YY4)
Old 09-05-2012, 9:35 AM   #2
961 961 is offline
Thanks: Gave 222, Got 599
Although I don't see the picture the centre speaker needs to go under the tv
Often it is possible for it to go on one side of the centre column. Otherwise the only answers are either a new stand with the centre column at the rear allowing open access at the front, or a smaller centre speaker
Old 09-05-2012, 10:34 AM   #3
thanks for your reply.
I would rather not replace the whole cabinet. However, I wonder if I might be ableto modify the centre support to match what you suggest.
Old 09-05-2012, 10:37 AM   #4
Alternatively.
A Kef T101 speaker would actually fit BEHIND the TV. (there is a 3cm gap between bottom of tv and shelf below).
United Kingdom - Showroom - T101c
this seems like a bad idea though - anyone ever tried anything like this ?
Old 09-05-2012, 10:41 AM   #5
thinking aloud
The T101 could actually be securedto teh front of the cabinet just above the TV.
Why did you say the centre speaker should be BELOW the tv ?
Old 09-05-2012, 11:12 AM   #6
961 961 is offline
Don't put the speaker behind, it'll ruin the sound
Below the tv because the physical dangers to the tv, children etc of a heavy speaker above the tv, unless it is on a stout shelf, are serious
TV Stands UK & Television Furniture with Free UK Delivery
http://www.amazon.co.uk/MountRight-T...ref=pd_cp_ce_0
Old 09-05-2012, 11:21 AM   #7
961 961 is offline
I've got the picture now
What you need is an additional side cabinet so that the speakers can go where the flowers are
Can the centre speaker fit into the shelving immediately above the tv? It really doesn't matter if it is slightly off centre
Old 09-05-2012, 6:11 PM   #8
I think the side speakers can get mounted in the cabinet to the side (the doors can be trimmed or moved up).
Is it really not a problem if the center speaker is completely off center ?
Old 09-05-2012, 7:40 PM   #9
961 961 is offline
It should be just fine
Mine is off centre for exactly the same reason
