Req: Advice on speaker stand purchase
Old 22-08-2004, 5:18 PM   #1
6,432, Level: 19
Points: 6,432, Level: 19 Points: 6,432, Level: 19 Points: 6,432, Level: 19
Thanks: Gave 1, Got 2
I have PMC TB2 speakers
Size of base= 12" x 8"
Speaker height =16"
What size of base plate and top plate would u recommend? Most seem to have top plates of small size. Is this ok for stability?
I think the height has to be either 16"(40) or 20"(50 cms) to align to ear level.
Any recommendations please?
Old 23-08-2004, 2:20 PM   #2
Knightshade's Avatar
11,666, Level: 25
Points: 11,666, Level: 25 Points: 11,666, Level: 25 Points: 11,666, Level: 25
Thanks: Gave 13, Got 51
Hi Manhar,
Atacama make some nice stands. Small top plates and wide bases. I used to have a set and always found them very good. Used Tannoy Eysis 1's with them. again very narrow speaker. You'll probably look at the se 5 or 6.
http://www.atacama-audio.co.uk/
Hope this helps
