I have the AV10 extended, with the chunky legs. I concur with the build quality, however there is a problem with the intermediate shelves, that sit on the adjustable pegs, in as much as the pegs can pull out, collapsing the shelf, if too heavy a piece of equipment is put on them, or as in my case, when I leaned on it whilst connecting it up. Amps should be confined to the fixed shelves. The addition of an AV10 Floor Isolation Slab, gives room for equipment up to 80mm high, such as SKY Boxes etc. I also have two Transition Wall Supports, used to carry the surround amps. They are attractive to look at, and very strong, with minimum brackets, and will hold up to 30Kgs.
As my equpment expands, I am thinking of a adding a compact TV Cabinet, with the etched doors, as some of the new boxes do not match the original TagMclaren items. As ever with a cabinet, cooling becomed the problem, I saw advertised an enclosed cabinet with a built in cooling system, I tried to incorporate such a system in a wooden cabinet, using CPU fans. Even after mounting the fans undrneath the unit, on rubber shocks, and surrounding them with polystyrene, one could still hear the fan in the background, though no louder than a computer, or projector fan. Manufacturers recommend 100mm (4" space) above and to the sides of most equipment. Even on standby, my TAG processor gets quite hot, with 50mm of space above, and open at the back and sides.
