Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Other Home Cinema Components > AV Stands, Cabinets, Seating and Furniture
Latest popular product pricesPowered by
John Lewis Ellis Entertainment Unit, Dark
John Lewis Ellis Entertainment Unit, Light
John Lewis Maharani Corner TV Unit
John Lewis Matilda Bar Chair, Black
John Lewis Ellis Entertainment Unit, ...
John Lewis Stowe TV Unit
Oakland TV unit
Solo Flatscreen TV Entertainment Unit
TV entertainment unit
low entertainment unit
Caxton Royale wide TV entertainment unit
 More...Prices updated March 21st at 9:30pm and include delivery.
Old 27-05-2004, 11:35 PM   #1 (permalink)
I need racking for 800 dvds including boxsets!
Hi, I've got a gargantuan dvd collection of around 800 discs! The problem now is storing them all. Ideally I'd like shelves with doors on to keep out dust etc. But I've not seen any cabinets/cupboards that are of sufficiently narrow depth (around 18-20 cms). I don't really want exposed shelves as this looks untidy.
Any recommendations?
P.s. anyone who replies gets a free cdwow link. Will take £1.50 off all dvds and £1 off cds.
Gorshin is offline   Reply With Quote
Old 28-05-2004, 5:21 AM   #2 (permalink)
Parmenion's Avatar
Thanks: Gave 9, Got 18
I've had the opportunity to see many different items of furniture both with and without doors but I have to say I don't think I have ever seen a shelving unit with doors that is as narrow as you have specced.
I have had a few successes "modding" furniture from Ikea and the like and I'm just wondering if this may be an alternative.
If you are worried about ending up with some sort of Heath Robinson affair, with a bit of care and attention you can end up with a very respectable unit.
regards
Parmenion
Parmenion is offline   Reply With Quote
Old 28-05-2004, 7:53 AM   #3 (permalink)
eviljohn2's Avatar
Thanks: Gave 78, Got 217
I agree with Parmenion, if you can't find exactly what you want you'll be better off doing it yourself.
Although I've not tried it, the idea behind this CD rack looks remarkably easy to adapt and adding 2 hinges and a door shouldn't be too hard. http://www.tnt-audio.com/clinica/babelle_e.html
eviljohn2 is offline   Reply With Quote
Old 28-05-2004, 9:52 AM   #4 (permalink)
Clint C's Avatar
Thanks: Gave 10, Got 4
Gorshin, check this out http://www.ikea.co.uk/webapp/wcs/sto...ts=10115*10170
Is this what you're looking for? Width: 42 cm, Depth: 19 cm, Height: 170 cm. They're on my list of things to buy, I actually need 2 but will probably buy 3 to cover any future DVD purchases.
Clint.
NEC HT1100, Ruark Talisman II, Ruark Dialogue One, Ruark Epilogue, BK XLS 200, Onkyo 605, Humax HDCI-2000, HTPC, PS3 4 Blu-Ray
Clint C is offline   Reply With Quote
Old 28-05-2004, 11:18 AM   #5 (permalink)
Thanks: Gave 33, Got 36
The Ikea Billy storage range includes a CD/DVD rack 20 cm wide and 17 cm deep by about 200cm high. If you put two of these together you can then fit the doors which are made for the billy range - either solid or glass fronted. I have four of them with 2 glass fronted doors fitted. Not sure how many you would need for 800 DVds.
Check out the Ikea website. If you're interested I could try to post a pic of mine.
philipb is offline   Reply With Quote
Old 30-05-2004, 11:49 AM   #6 (permalink)
Thanks: Gave 10, Got 16
Gorshin,
Like Clint says, check out the Bertby wall cabinet at Ikea.
My hubby had the same concerns as you, and we found them perfect for our needs. We have 1 in the living room and 1 in a spare room.
Umu
UZUBAIRU is offline   Reply With Quote
Old 30-05-2004, 12:28 PM   #7 (permalink)
Nowhere near big enough!!!!!!!
I need a rack that is about eight foot by six foot tall!!!!
help!
Old 30-05-2004, 1:03 PM   #8 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 97, Got 1,360
If your needs are that specific i would contact a local cabinetb maker who can do you built in cabinets, floor to ceiling and all ready fitted with custom sized doors.
Or try a local chipy.
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 30-05-2004, 4:38 PM   #9 (permalink)
Thanks: Gave 9, Got 2
good luck in your search. i have as yet come to the conclusion there is nothing suitable for the kinda numbers both you and i have got. i have ended up using cd folders from maplins to store most of my films i dont watch as much and store about 300 most watched on slim dvd/cd tower units from ikea...
p.s. good to see someone as mad as myself at buying dvds. i am up to about a thousand so far. i have tried to give up/ slow down but cdwow keep roping me back...
evilash is offline   Reply With Quote
Old 30-05-2004, 5:58 PM   #10 (permalink)
Clint C's Avatar
help!
What's the problem... you only need to buy 5 of them and you're sorted . IIRC each one holds about 160 DVDs.
Clint
Old 30-05-2004, 6:23 PM   #11 (permalink)
Muzic man's Avatar
Thanks: Gave 0, Got 4
I cant believe anyone in their right mind would spend £55 on a Dvd cuboard !!
I went to the local Homebase, bought a pine shelving unit for £16 (6 shelves)added some 33mm X 33mm batten to the back of each shelf and scewed it to the wall. It holds 39 Dvds per shelf (43 carboard covers). The Dvds sit perfectly ,half inch in with about half inch above. You can also buy a 4 shelf for £10. : :
Muzic man is offline   Reply With Quote
Old 30-05-2004, 10:28 PM   #12 (permalink)
leon's Avatar
Thanks: Gave 0, Got 37
hello
they are not inclosed but have a nice trendy finish
try these guys i think there systems all inter lock
http://www.boltz.com/productinfo.asp?item=MM-252&deptcode1=501
leon is offline   Reply With Quote
Old 30-05-2004, 11:26 PM   #13 (permalink)
Clint C's Avatar
Originally Posted by Muzic man
I cant believe anyone in their right mind would spend £55 on a Dvd cuboard !! :
Only if they wanted it to look half decent... anyway, who says we're in our right minds .
Gorshin's spec was "Ideally I'd like shelves with doors on to keep out dust etc.". Also "I don't really want exposed shelves as this looks untidy". Just trying to help Gorshin out...
Old 31-05-2004, 6:02 PM   #14 (permalink)
Thanks: Gave 47, Got 305
Gorshin,
You could try the VÄTTERN range from Ikea,
http://www.ikea.co.uk/webapp/wcs/sto...hapterId=10138
Although they are bathroom cabinets they work perfectly for DVD's as they are only 19cm deep and are available in 40cm or 30cm wide cabinets. You can also get doors for them. With 7 glass shelves in them I fitted about 650 in 2 x40cm and 2 x 30cm cabinets.
If you search the forum you should find a thread with pictures of them setup (I borrowed the idea off the poster )
lfletcher is offline   Reply With Quote
Old 10-06-2004, 10:17 PM   #15 (permalink)
lazarus's Avatar
this is what i went for - i have 800 or so dvds and i bought 9 of these bookcases and have arranged them in a 3 by 3 setup. the beech effect is actually quite smart
http://www.argos.co.uk/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=1751&productId=93496&Trail=C$cip=12217 >C$cip=12218>C$cip=12226&categoryId=12226
heres a thread of mine from a while back about dvd storage
DVD Storage
lazarus is offline   Reply With Quote
800, boxsets, dvds, including, racking
Copyright © 2000-2010 M2N E. & O. E.
