Ikea lack tv unit help.
Old 20-11-2009, 7:14 PM   #1
2,517, Level: 11
Points: 2,517, Level: 11 Points: 2,517, Level: 11 Points: 2,517, Level: 11
How can i modify the shelve height in order to fit a AV Receiver into it?
Many thanks.
Old 22-11-2009, 3:27 PM   #2
Iron Man 2's Avatar
4,407, Level: 15
Points: 4,407, Level: 15 Points: 4,407, Level: 15 Points: 4,407, Level: 15
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 109, Got 62
Many thanks.
You might struggle. I was in Ikea yesterday and seen this stand. The shelve height is only about 150mm. There isnt much room to drop it. Google Ikea Hackers with the tv stand name.
Old 23-11-2009, 4:24 PM   #3
2,517, Level: 11
thanks mate, i will have a spare shelf when i reduce it from 3 to 2 but i have heard they are hollow and i wont get the finished edge if i cut it up.
