Wall Mounted TV - Where do I put my xbox?
Old 18-11-2009, 1:58 PM   #1
1,376, Level: 8
Points: 1,376, Level: 8 Points: 1,376, Level: 8 Points: 1,376, Level: 8
Hello
First post here, just need a little advice as you all appear to have a wealth of knowledge available on these things.
I have just mounted my 32" TV on the wall in my bedroom. Has anyone any suggestions where I could now put my xbox, dvd player and surround sound devices? I was thinking some kind of cabinet, but i cannot find one thin enough, i.e about the same width as a 32" tv and not too high? Any suggestions or examples?
Michael
Old 19-11-2009, 9:23 PM   #2
1,680, Level: 9
Points: 1,680, Level: 9 Points: 1,680, Level: 9 Points: 1,680, Level: 9
Thanks: Gave 0, Got 23
Hi Monty 187,
When we put our plasma on the wall we needed somewhere to put all our bits and pieces.
Have a look at putting AVracks or HiFi stands into your search engine, you will probably find something from that I am sure. I bought the Portability GT6 which can be built with either 4 or 5 shelves.
I also looked at Amazon and Ikea. Takes a bit of time to find somthing but its worth it.
Hope this helps.
Old 20-11-2009, 9:04 AM   #3
1,376, Level: 8
Cheers for that, I have been looking but perhaps not in the right places. Ill have a look this evening!!
Old 20-11-2009, 10:10 AM   #4
1,675, Level: 9
Points: 1,675, Level: 9 Points: 1,675, Level: 9 Points: 1,675, Level: 9
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 1, Got 51
The portability GT6 hifi stand is an excellent product and unbeatable value for money.
There is also two DVD shelf brackets, a one shelf bracket and a two shelf bracket, these are modern solutions which are placed just beneath your wall mounted TV and both feature a cable tidy system.
If you need any further info just let us know.
Last edited by inzaman; 20-11-2009 at 9:26 PM. Reason: Removed text that breaks forum rule no. 7
Old 20-11-2009, 11:03 AM   #5
1,376, Level: 8
Cheers Paul, the rack does look like what i need. I dont want to make any more holes in the wall as I am only renting at the moment.
Old 20-11-2009, 7:11 PM   #6
1,680, Level: 9
Hi Monty 187,
As I said in my earlier post I have the Portability GT6 stand, IMO it is a nice stand. A bit of advice if you go for this then two things, shop around prices vary widely and two when you put it together make sure there are two of you. Its easier to put together then.
Good luck.
Waterhorse.
Old 23-11-2009, 9:00 AM   #7
1,376, Level: 8
thanks for that
